Main reason is: because it was easier for me to implement the binding that way. Zone things have many channels and I wasnât sure which of them should be contact, and for which of them a switch would be better. For some of them you can send commands (BYBASS), some of them obviously should be contact (VIOLATION), but the rest isnât so obvious, so I decided to use switch type for all of them. That maybe wasnât a good decision, but now it is not easy to change it.
Besides OH is very flexible and you can achieve whatever you want in many ways. You can for example rename icons (or copy to new files) door-open.png
and voilĂ , you have dynamic icon for doors.
Thank you for your hint regarding dynamic icons. In addition I have changed Switch item type into String type on site map so there are no switches for violation itemsđ
New questions and observations:
What is the difference between
Armed
channel andReally Armed
channel in Partition thing? -
When I am setting Armed in OH2 (using
Armed
channel) and I have a blocked or violated zone ( ex open window) the satel is arming despite that Force Arming option in Partition thing is off. -
When I am setting Armed in OH2 for partition with a given time to leave option in Satel(ex 30 sec) the thing changes back into Disarmed then after ~30esc it changes into Armed, as follows:
2020-10-05 21:10:43.692 [ome.event.ItemCommandEvent] - Item 'Satel_PARTITION_1_ARMED' received command ON
2020-10-05 21:10:43.710 [nt.ItemStatePredictedEvent] - Satel_PARTITION_1_ARMED predicted to become ON
2020-10-05 21:10:43.758 [vent.ItemStateChangedEvent] - Satel_PARTITION_1_ARMED changed from OFF to ON
2020-10-05 21:10:45.420 [vent.ItemStateChangedEvent] - Satel_PARTITION_1_ARMED changed from ON to OFF
2020-10-05 21:11:14.171 [vent.ItemStateChangedEvent] - Satel_PARTITION_1_ARMED changed from OFF to ON
I have already put this statement before, but once again:
I am not professional security installer, just a developer of this binding. I have some knowledge of Satel alarms, but I donât know all the configuration options and the way they work. So please donât ask me what is this feature for, what is that option for, etc. I have just implemented the integration protocol basing on the documentation, but I donât know the meaning and purpose of all those things
As far as I know, âarmedâ is when the system is going to arm, when you pressed âarmâ button but exit time have not passed. âReally armedâ is when the system is indeed armed and all the violations trigger an alarm.
My observation is the alarm is not armed, however the binding shows it is. Which is weird, but I donât think this is a bug in the binding.
I donât have âArmedâ item, I use âReally armedâ channel.
Ok, clear enough and thank you for binding!
This also directed me to look first at the int-rs protocol description for explenation. And I have found a direct answer to my question:
There is a note:
for INTEGRA v1.12 and newer, both 0x09 and 0x0A commands indicate really armed partitions, regardless of suppression arm status time.
As I have Integra v1.19 there should not be any difference between both
I assume that most users of the satel binding are not the satel professional installers so I think this forum might serve for exchange of experience regarding satel binding setting and knowledge as well
Somehow I missed this info, thanks. Good to know.
Hi druciak
I have defined all items and things (~40) which are feeded by Satel binding and I am observing them now while not changing/adding any thing new. Unfortunattely my binding is not reliable yet
First I have observed that quite often my INT-RS bridge is disconnected and in the next second it is connected back.I have used and modify your program I found here https://community.openhab.org/t/satel-lack-of-module-connected-and-module-connected-since/50639/3 to calculate number of disconnect/connect and there are about 20 from last day like the following:
2020-10-09 15:30:14.638 [hingStatusInfoChangedEvent] - 'satel:int-rs:46d26acd' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2020-10-09 15:30:15.269 [hingStatusInfoChangedEvent] - 'satel:int-rs:46d26acd' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
The above would not be an issue since 1 second of disconnection is not a problem.
But I have experienced also that after ~1 day of working there is a disconnection without connection back and the message in the log refers to time out.
Sometimes when I click on my INT-RS bridge in paper UI connection goes back but sometime I must stop and restart openhab to have satel binding working back.
I have set up the INT-RS bridge with time out is set to 5000ms and refresh to 1000ms.
Majority of satel binding enthusiasts have ETHM-1 and not sure if they signal any similar issue in their environments?
Any hints what to investigate further?
Does it disconnect after specific command sent or there is no pattern and diconnections happen at random?
To check this please enable debug logging level and observe for some time if it always disconnects after the same command or different ones.
It is random.
I have set up DEBUG level for a separate log fille. Then I restarted openhab at 18:04. The first disconnection/reconnection event took place at 20:25 but I can not find an evidence of it in the separate logfile(?)
But I can see that starting at 19.40 there are some strange (?) lines in the log as follows:
11-Oct-2020 19:40:48.010 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
11-Oct-2020 19:40:48.037 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 7F, payload = FC FD 7F FF FF
11-Oct-2020 19:40:48.039 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: NewStatesEvent: changed = [02,03,04,05,06,07,08,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
11-Oct-2020 19:40:50.010 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
11-Oct-2020 19:40:50.030 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 7F, payload = FD FD 7F FF FF
11-Oct-2020 19:40:50.033 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: NewStatesEvent: changed = [00,02,03,04,05,06,07,08,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
11-Oct-2020 19:40:50.036 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.038 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.040 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.041 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.043 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.044 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.046 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.048 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.050 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.052 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.053 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.055 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.056 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.058 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.060 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.061 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.063 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.065 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.066 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.068 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.070 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.072 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.073 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 19:40:50.074 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 00, payload =
11-Oct-2020 19:40:50.106 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 00, payload = 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00
11-Oct-2020 19:40:50.107 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: IntegraStateEvent: command = 00, extended = false, active = {18}
11-Oct-2020 19:40:52.011 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
11-Oct-2020 19:40:52.033 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 7F, payload = FC FD 7F FF FF
11-Oct-2020 19:40:52.037 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: NewStatesEvent: changed = [02,03,04,05,06,07,08,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
11-Oct-2020 19:40:54.011 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
11-Oct-2020 19:40:54.038 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 7F, payload = FC FD 7F FF FF
The above lines repate then from time to time. Not sure if this might lead somehow to disconnection?
I donât see any disconnection on this log excerpt. What makes you think this log is suspicious? I donât see anything that could cause troubles.
Please try to catch a disconnection while having DEBUG level turned on. What is interesting happens just before it. It would be good to have 2-3 occurrences logged.
Please find below, 3 occurences as follows (click on arrows):
yesterday at 22:25
11-Oct-2020 20:25:47.175 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 00, payload =
11-Oct-2020 20:25:47.176 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 00, payload =
11-Oct-2020 20:25:47.208 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 00, payload = 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00
11-Oct-2020 20:25:47.209 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: IntegraStateEvent: command = 00, extended = false, active = {19}
11-Oct-2020 20:25:49.122 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
11-Oct-2020 20:25:53.123 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 7F, payload =
11-Oct-2020 20:25:54.145 [DEBUG] [penhab.binding.satel.internal.protocol.IntRSModule] - Closing connection to INT-RS module
11-Oct-2020 20:25:57.130 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 7F, payload =
11-Oct-2020 20:25:57.150 [INFO ] [penhab.binding.satel.internal.protocol.IntRSModule] - Connection to INT-RS module has been closed
11-Oct-2020 20:25:57.151 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: org.openhab.binding.satel.internal.event.ConnectionStatusEvent: connected = false, reason = null
11-Oct-2020 20:25:57.187 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Communication thread stopped
11-Oct-2020 20:25:57.991 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Communication thread started
11-Oct-2020 20:25:57.996 [INFO ] [penhab.binding.satel.internal.protocol.IntRSModule] - Connecting to INT-RS module at /dev/USB-satel
11-Oct-2020 20:25:58.006 [INFO ] [penhab.binding.satel.internal.protocol.IntRSModule] - INT-RS module connected successfuly
11-Oct-2020 20:25:58.008 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
11-Oct-2020 20:25:58.035 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 7F, payload = FD FD 7F FF FF
11-Oct-2020 20:25:58.037 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: org.openhab.binding.satel.internal.event.ConnectionStatusEvent: connected = true, reason = null
11-Oct-2020 20:25:58.136 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: NewStatesEvent: changed = [00,02,03,04,05,06,07,08,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
11-Oct-2020 20:25:58.137 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 17, payload =
today at 22:04
12-Oct-2020 22:04:22.889 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 7F, payload = FC FD 7F FF FF
12-Oct-2020 22:04:22.894 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: NewStatesEvent: changed = [02,03,04,05,06,07,08,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
12-Oct-2020 22:04:24.865 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
12-Oct-2020 22:04:28.866 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 7F, payload =
12-Oct-2020 22:04:29.898 [DEBUG] [penhab.binding.satel.internal.protocol.IntRSModule] - Closing connection to INT-RS module
12-Oct-2020 22:04:32.875 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 7F, payload =
12-Oct-2020 22:04:32.904 [INFO ] [penhab.binding.satel.internal.protocol.IntRSModule] - Connection to INT-RS module has been closed
12-Oct-2020 22:04:32.907 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: org.openhab.binding.satel.internal.event.ConnectionStatusEvent: connected = false, reason = null
12-Oct-2020 22:04:32.939 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Communication thread stopped
12-Oct-2020 22:04:33.393 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Communication thread started
12-Oct-2020 22:04:33.394 [INFO ] [penhab.binding.satel.internal.protocol.IntRSModule] - Connecting to INT-RS module at /dev/USB-satel
12-Oct-2020 22:04:33.404 [INFO ] [penhab.binding.satel.internal.protocol.IntRSModule] - INT-RS module connected successfuly
12-Oct-2020 22:04:33.406 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
12-Oct-2020 22:04:33.427 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 7F, payload = FC FD 7F FF FF
12-Oct-2020 22:04:33.428 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: org.openhab.binding.satel.internal.event.ConnectionStatusEvent: connected = true, reason = null
12-Oct-2020 22:04:33.482 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: NewStatesEvent: changed = [02,03,04,05,06,07,08,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
12-Oct-2020 22:04:33.485 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 17, payload =
12-Oct-2020 22:04:33.486 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 17, payload =
today at 22:39
12-Oct-2020 22:39:07.764 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 7F, payload = FC FD 7F FF FF
12-Oct-2020 22:39:07.768 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: NewStatesEvent: changed = [02,03,04,05,06,07,08,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
12-Oct-2020 22:39:09.742 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
12-Oct-2020 22:39:13.743 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 7F, payload =
12-Oct-2020 22:39:14.774 [DEBUG] [penhab.binding.satel.internal.protocol.IntRSModule] - Closing connection to INT-RS module
12-Oct-2020 22:39:17.745 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 7F, payload =
12-Oct-2020 22:39:17.778 [INFO ] [penhab.binding.satel.internal.protocol.IntRSModule] - Connection to INT-RS module has been closed
12-Oct-2020 22:39:17.780 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: org.openhab.binding.satel.internal.event.ConnectionStatusEvent: connected = false, reason = null
12-Oct-2020 22:39:17.811 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Communication thread stopped
12-Oct-2020 22:39:18.794 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Communication thread started
12-Oct-2020 22:39:18.795 [INFO ] [penhab.binding.satel.internal.protocol.IntRSModule] - Connecting to INT-RS module at /dev/USB-satel
12-Oct-2020 22:39:18.812 [INFO ] [penhab.binding.satel.internal.protocol.IntRSModule] - INT-RS module connected successfuly
12-Oct-2020 22:39:18.814 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Sending message: Message: command = 7F, payload =
12-Oct-2020 22:39:18.830 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Got response: Message: command = 7F, payload = FD FD 7F FF FF
12-Oct-2020 22:39:18.831 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: org.openhab.binding.satel.internal.event.ConnectionStatusEvent: connected = true, reason = null
12-Oct-2020 22:39:18.851 [DEBUG] [enhab.binding.satel.internal.event.EventDispatcher] - Distributing event: NewStatesEvent: changed = [00,02,03,04,05,06,07,08,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
12-Oct-2020 22:39:18.854 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 17, payload =
12-Oct-2020 22:39:18.856 [DEBUG] [penhab.binding.satel.internal.protocol.SatelModule] - Command already in the queue: Message: command = 17, payload =
I do not see any suspect apart from disconnection/connection info
@druciak I have no issues with the module, just wanted to thank you for your great work on this. It must have taken tons of your time, it works great. Thank you.
After upgrading to 3.0 my Satel binding stoped working.
When I open thing â ETHM-1â I seen an error:
Status:
OFFLINE
**COMMUNICATION_ERROR**
IO error occurred while connecting socket
Everything worked perfectly fine on 2.4.
I run openhab in docker and upgraded by installing a newer image
Hi @olega
I havenât tested the binding on OH3 yet, I will try on the weekend.
Do you have more logs, stack trace or anything that could help addressing the issue?
Here is the debug log:
23:10:01.199 [DEBUG] [g.satel.internal.protocol.SatelModule] - Connection failed
org.openhab.binding.satel.internal.protocol.SatelModule$ConnectionFailureException: IO error occurred while connecting socket
at org.openhab.binding.satel.internal.protocol.Ethm1Module.connect(Ethm1Module.java:85) ~[bundleFile:?]
at org.openhab.binding.satel.internal.protocol.SatelModule.communicationLoop(SatelModule.java:384) [bundleFile:?]
at org.openhab.binding.satel.internal.protocol.SatelModule$CommunicationWatchdog$2.run(SatelModule.java:520) [bundleFile:?]
at java.lang.Thread.run(Thread.java:834) [?:?]
Caused by: java.io.IOException: General encryption failure
at org.openhab.binding.satel.internal.protocol.Ethm1Module$EncryptedCommunicationChannel.<init>(Ethm1Module.java:134) ~[bundleFile:?]
at org.openhab.binding.satel.internal.protocol.Ethm1Module.connect(Ethm1Module.java:80) ~[bundleFile:?]
... 3 more
Caused by: java.security.GeneralSecurityException: JCE does not support 192-bit keys
at org.openhab.binding.satel.internal.protocol.EncryptionHelper.<init>(EncryptionHelper.java:43) ~[bundleFile:?]
at org.openhab.binding.satel.internal.protocol.Ethm1Module$EncryptedCommunicationChannel.<init>(Ethm1Module.java:132) ~[bundleFile:?]
... 3 more
23:10:01.222 [DEBUG] [.satel.internal.event.EventDispatcher] - Distributing event: org.openhab.binding.satel.internal.event.ConnectionStatusEvent: connected = false, reason = IO error occurred while connecting socket
23:10:02.980 [DEBUG] [l.internal.handler.SatelBridgeHandler] - Module not initialized yet, skipping refresh
23:10:07.986 [DEBUG] [l.internal.handler.SatelBridgeHandler] - Module not initialized yet, skipping refresh
Same occurs in 2.5
Actually I just managed to fix it by adding env variable in docker
CRYPTO_POLICY: "unlimited"
Yes, that was the reason, I am glad you solved the issue.
Is the binding working without any problems now? Are there any other issues on OH3?
After upgrading to 3.0 (same issue is also in snapshot 3.1.0) the automatic discovery of things with ETHM-1 no longer works. In previous versions this has been working flawlessly. Manual adding of things continues to work fine.
I get the following error message from the discovery (note highlighted mismatch of thing and bridge UIDs which seems to cause the problem; my correct bridge UID is âsatel:ethm-1:71a70daa2dâ; if I manually add a satel:system it gets a different UID):
2021-01-03 12:39:40.419 [ERROR] [nternal.DiscoveryServiceRegistryImpl] - Cannot trigger scan for thing types '[satel:event-log, satel:partition, satel:atd-100, satel:output, satel:zone, satel:shutter, satel:system]' on 'SatelDeviceDiscoveryService'!
java.lang.IllegalArgumentException: Thing UID 'satel:system:71a70daa2d' does not match bridge UID 'satel:ethm-1:71a70daa2d'
at org.openhab.core.config.discovery.DiscoveryResultBuilder.validateThingUID(DiscoveryResultBuilder.java:172) ~[bundleFile:?]
at org.openhab.core.config.discovery.DiscoveryResultBuilder.withBridge(DiscoveryResultBuilder.java:120) ~[bundleFile:?]
at org.openhab.binding.satel.internal.discovery.SatelDeviceDiscoveryService.addThing(SatelDeviceDiscoveryService.java:163) ~[?:?]
at org.openhab.binding.satel.internal.discovery.SatelDeviceDiscoveryService.startScan(SatelDeviceDiscoveryService.java:77) ~[?:?]
at org.openhab.core.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:194) ~[bundleFile:?]
at org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:377) [bundleFile:?]
at org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:362) [bundleFile:?]
at org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:211) [bundleFile:?]
at org.openhab.core.io.rest.core.internal.discovery.DiscoveryResource.scan(DiscoveryResource.java:105) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) [bundleFile:1.0.9]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) [bundleFile:1.0.9]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) [bundleFile:1.0.9]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) [bundleFile:1.0.9]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) [bundleFile:1.0.9]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) [bundleFile:1.0.9]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:267) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:216) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:301) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:220) [bundleFile:1.0.9]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) [bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:276) [bundleFile:1.0.9]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
Same issue here.
Did u find walkaround or stick to manual conf.?
2021-01-04 15:57:34.750 [ERROR] [nternal.DiscoveryServiceRegistryImpl] - Cannot trigger scan for thing types '[satel:atd-100, satel:partition, satel:event-log, satel:system, satel:shutter, satel:zone, satel:output]' on 'SatelDeviceDiscoveryService'!
java.lang.IllegalArgumentException: Thing UID 'satel:system:e2e48b9020' does not match bridge UID 'satel:ethm-1:e2e48b9020'
@druciak is there any quick fix for this?
I will look into this issue ASAP.
