i try to save my dimmer value before i switch off.
after i switch my light back on i will have the same dimmer value as before.
rule "Wohnzimmerschalter"
Item Wohnzimmerlicht changed
if (Wohnzimmerlicht.state == OFF)
var Number altWohnzimmerlicht = WohnzimmerBrightness.state
WohnzimmerBrightness.sendCommand("0")
}else
WohnzimmerBrightness.sendCommand(altWohnzimmerlicht)
i got this error
20:52:05.969 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Wohnzimmerschalter': The name 'altWohnzimmerlicht' cannot be resolved to an item or type; line 626, column 36, length 18
20:52:05.970 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Wohnzimmerschalter': The name 'altWohnzimmerlicht' cannot be resolved to an item or type; line 626, column 36, length 18
hi hannes,
i think you have to declare the variable outside of the function, because when light changes to off the function is called and parameter is saved. but wenn light changes on the function is called again and then no value is there (because we are in the “else”-condition only)
var altWohnzimmerlicht = 0
altWohnzimmerlicht = (WohnzimmerBrightness.state as Number).intValue
}else
but normally when switching off a light with “OFF” instead of “0” then the last state might be restored when switching light “ON” again - even if it is a dimmer. at least for me that works.
