I have an openhab3 server running on a raspi. I went through the whole setup of items, sitemap etc. and am now in the middle of setting up several rules to have my home automation work together.
Since a few days I receive an JAVA error in the output section of Visual Studio Code when saving the rules file.
Here is the error message I receive:
[Error - 10:40:26] Request textDocument/definition failed.
Message: Internal error.
Code: -32603
java.util.concurrent.CompletionException: java.lang.RuntimeException: Cannot create a resource for 'java:/Objects/org.openhab.core.model.script.actions.BusEvent'; a registered resource factory is needed
at java.base/java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:331)
at java.base/java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:346)
at java.base/java.util.concurrent.CompletableFuture$UniAccept.tryFire(CompletableFuture.java:704)
at java.base/java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:506)
at java.base/java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:2088)
at org.eclipse.xtext.ide.server.concurrent.AbstractRequest.logAndCompleteExceptionally(AbstractRequest.java:73)
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$doRun$0(ReadRequest.java:69)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.lang.RuntimeException: Cannot create a resource for 'java:/Objects/org.openhab.core.model.script.actions.BusEvent'; a registered resource factory is needed
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:263)
at org.eclipse.xtext.ide.server.ProjectManager.getResource(ProjectManager.java:169)
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:436)
at org.eclipse.xtext.ide.server.findReferences.WorkspaceResourceAccess.readOnly(WorkspaceResourceAccess.java:36)
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.doRead(DocumentSymbolService.java:332)
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:112)
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:99)
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$definition$24(LanguageServerImpl.java:603)
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:438)
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:602)
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:590)
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$definition$23(LanguageServerImpl.java:581)
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$doRun$0(ReadRequest.java:66)
... 5 more
Any hints/help where and how I shall start investigating that? Thanks a lot upfront.
