Sure this will work as well.
But the conversion from a Item String to String Type was already part of this “add-on”. So it seemed somewhat downgraded which should not happen.
There was no change on the concerned files since 2 months.
Are you sure you did not change something else ?
I will update to last snapshot this weekend and see if my say command in rules is still working.
