Hi
How do a get sonos to say the state of an item string?
Example:
the relay is (item State on/off)
Hi
Example:
Create the string like:
var String sayString ="The Relay is " + MyItem.state.toString
Hi
Should to type this in a rule, or what do you mean by create the string?
I assumed you have Sonos as well the tts service in OH set up correctly and were asking how to handover an item state to the say command. Using such a String would be the way.
However if you have more questions concerning the how to use TTS and Sonos via rules, please ask.
Thanks i got it
