My Rademacher thermostat handles the value for temperature in deci degree:
value 200 = 20°C
I was able to transform the input value with JS transformation:
(function(i) {
var o = JSON.parse(i);
var temp = o.device.position;
return(temp * 0.1);
})(input)
But how do I transform the output? I have to multiply the target temp with 10, but transformations are not possible with GET outputs (only with POST).
Thanks a lot for your help!!
Tim
