Its seems like after several reboots its now working… Below is my complete code, could maybe be written smaller and better, but I hope someone else might find it useful, Only thing not working is to have a dimmer to adjust red, green, blue value with the dimmer value, couldnt get it to work so left it out for now.
import org.eclipse.smarthome.core.library.types.HSBType
import org.eclipse.xtext.xbase.lib.*
var HSBType hsbValue
var HSBType hsbValueMasterBedRoom
var HSBType hsbValueBathRoom
val hsbOff = HSBType::fromRGB(0, 0, 0)
val hsbOn = HSBType::fromRGB(255, 255, 255)
var int redColor
var int greenColor
var int blueColor
var double dimmerValue =1.0
var int redValue
var int greenValue
var int blueValue
var String RGBvalues
////////////// Switch the different areas where LED-Lights should be switched on/off ////////////////7////////////
val Functions$Function3 rgbLights= [ GroupItem mainGroup,GroupItem subGroup, HSBType hsbValue |
//So all non scene group lights in livingroom get switched off if they not already are off
//val nonSceneLights = Group_DMX_LivingRoom.members.filter[l | !l.members(s as Group)]
//nonSceneLights.members.filter[l|l.state.toString != hsbOff.toString].forEach[l| l.sendCommand(hsbOff as Command)]
mainGroup.members.filter[l|l.state.toString != hsbOff.toString].forEach[l| l.sendCommand(hsbOff) ]
subGroup.members.forEach[l|l.sendCommand(hsbValue)]
//s.members.filter[l|l.state.toString != hsbValue.toString].forEach[l| l.sendCommand(hsbValue) ]
rule "Activate Scene LivingRoom"
Item Scene_LivingRoom1 received command or Item Scene_LivingRoom2 received command or Item Scene_LivingRoom3 received command
if ((receivedCommand>0) && (receivedCommand<5)) {
Scene_LivingRoom2.postUpdate(0)
Scene_LivingRoom3.postUpdate(0)
logInfo("Debug","Received command is " + receivedCommand.toString() + " we deactivate 2 and 3" )
else if ((receivedCommand>4) && (receivedCommand<9)) {
Scene_LivingRoom1.postUpdate(0)
logInfo("Debug","Received command is " + receivedCommand.toString()+ " we deactivate 1 and 3" )
else if ((receivedCommand>8) && (receivedCommand<13)) {
logInfo("Debug","Received command is " + receivedCommand.toString() + " we deactivate 1 and 2")
else{
logInfo("Debug","Received command is " + receivedCommand.toString() + " SHOULD NEVER HAPPEN")
switch receivedCommand {
//Default
case 0: {
//OFF
case 1:{
Group_DMX_LivingRoom.members.filter[l|l.state.toString != hsbOff.toString].forEach[l| l.sendCommand(hsbOff) ]
logInfo("Debug","turning off lights" )
//ON
case 2:{
Group_DMX_LivingRoom.members.filter[l|l.state.toString != hsbValue.toString].forEach[l| l.sendCommand(hsbOn) ]
logInfo("Debug","turning on lights" )
//Dinner
case 3:{
hsbValue = HSBType::fromRGB(255, 255, 153)
rgbLights.apply(Group_DMX_LivingRoom,Group_DMX_Dinner,hsbValue)
//Reading
case 4:{
rgbLights.apply(Group_DMX_LivingRoom,Group_DMX_Reading,hsbValue)
//FirePlace
case 5:{
hsbValue = HSBType::fromRGB(60, 60, 100)
rgbLights.apply(Group_DMX_LivingRoom,Group_DMX_FirePlace,hsbValue)
//Bar
case 6:{
rgbLights.apply(Group_DMX_LivingRoom,Group_DMX_Bar,hsbValue)
case 7:{
//TV
case 8:{
rgbLights.apply(Group_DMX_LivingRoom,Group_DMX_TV,hsbValue)
//Cooking
case 9:{
rgbLights.apply(Group_DMX_LivingRoom,Group_DMX_Cooking,hsbValue)
//Wall
case 10:{
rgbLights.apply(Group_DMX_LivingRoom,Group_DMX_Wall,hsbValue)
//Kitchen
case 11:{
hsbValue = HSBType::fromRGB(255, 255, 255)
rgbLights.apply(Group_DMX_LivingRoom,Group_DMX_Kitchen,hsbValue)
//Lounge
case 12:{
hsbValue = HSBType::fromRGB(255, 204, 51)
rgbLights.apply(Group_DMX_LivingRoom,Group_DMX_Lounge,hsbValue)
////////////// Change color freely ////////////////7////////////
rule "Set RGB value Living Room"
Item Color_LivingRoom changed
logInfo("Info", "Set RGB value Living Room to : " +redColor.toString+ ":" +greenColor.toString+ ":" +blueColor.toString)
hsbValue = Color_LivingRoom.state as HSBType
//redValue = (redColor*dimmerValue).intValue
//greenValue = (greenColor*dimmerValue).intValue
//blueValue= (blueColor*dimmerValue).intValue
//hsbValue = HSBType::fromRGB(redValue, greenValue,blueValue)
//logInfo("Info", "Set RGB value Living Room to : " +redValue.toString+ ":" +greenValue.toString+ ":" +blueValue.toString)
logInfo("Debug","changing on lights: " + l.state.toString+ " " + l.name )
////////////// Change the moodings of light, e.g. warm white, white, lounge and night ////////////////////////////
rule "Change the color in Living Room"
Item MoodSelector_LivingRoom received command
//warm white
if (receivedCommand==1) {
redColor = 255
greenColor = 0
blueColor =0
//white
if (receivedCommand==2) {
redColor = 0
greenColor = 255
blueColor =0
//lounge
if (receivedCommand==3) {
redColor = 0
greenColor = 0
blueColor =255
//night
if (receivedCommand==4) {
//255, 244, 229
redColor = 255
greenColor = 244
blueColor =229
hsbValue = HSBType::fromRGB(redColor, greenColor,blueColor)
Color_LivingRoom.sendCommand(hsbValue)
rule "Change dimming in Living Room"
Item Dimmer_LivingRoom changed
logInfo("Debug","Dimmer state: " )
dimmerValue = 0.2//Dimmer_LivingRoom.state as DecimalType
* ************************************** MASTER BEDROOM ***************************************************
rule "Set RGB value MasterBedRoom"
Item Color_MasterBedRoom changed
hsbValueMasterBedRoom = Color_MasterBedRoom.state as HSBType
Group_DMX_MasterBedRoom.members.filter[l|
].forEach[l| l.sendCommand(hsbValueMasterBedRoom) ]
////////////// Change the scene of light, e.g. warm white, white, lounge and night ////////////////////////////
rule "Change the scene in Master Bedroom"
Item Scene_MasterBedRoom received command
//warm white
//OFF
case 1: {
hsbValueMasterBedRoom = HSBType::fromRGB(0, 0, 0)
Group_DMX_MasterBedRoom.members.forEach[l|l.sendCommand(hsbValueMasterBedRoom)]
logInfo("Info", "Set RGB value Master Room to :")
//ON
case 2:{
hsbValueMasterBedRoom = HSBType::fromRGB(255, 255, 255)
rgbLights.apply(Group_DMX_MasterBedRoom,Group_DMX_MasterBedRoom,hsbValueMasterBedRoom)
logInfo("Info", "Set RGB value Master Room to ON :")
//NIGHT
case 3:{
hsbValueMasterBedRoom = HSBType::fromRGB(50, 10, 10)
//READING
case 4:{
hsbValueMasterBedRoom = HSBType::fromRGB(200, 200, 100)
* ***************************************** BATHROOM ***********************************************
rule "Set RGB value BathRoom"
Item Color_BathRoom changed
hsbValueBathRoom = Color_BathRoom.state as HSBType
Group_DMX_BathRoom.members.filter[l|
].forEach[l| l.sendCommand(hsbValueBathRoom) ]
rule "Change the scene in Bathroom"
Item Scene_BathRoom received command
//warm white
//OFF
case 1: {
hsbValueBathRoom = HSBType::fromRGB(255, 0, 0)
Group_DMX_BathRoom.members.forEach[l|l.sendCommand(hsbValueBathRoom)]
//ON
case 2:{
hsbValueBathRoom = HSBType::fromRGB(255, 255, 255)
rgbLights.apply(Group_DMX_BathRoom,Group_DMX_BathRoom,hsbValueBathRoom)
//NIGHT
case 3:{
hsbValueBathRoom = HSBType::fromRGB(50, 10, 10)
//SHOWER
case 4:{
hsbValueBathRoom = HSBType::fromRGB(200, 200, 100)
