hi every body i’m new in the community but i discovered openhab since openhab v1
i d’ont use it before because of programmation file now that done with UI it’s more easy maybe more buggy
Platform information: Synology ds418play 2GB Ram in docker
Hardware: CPUArchitecture/RAM/storage cpu Intel Celeron J3355 Dual Core ( 2 GHz - Turbo 2.5 GHz) 2GB RAM DDR3 60% of use
OS: what OS is used and which versionDSM 6.2 (Docker)
Java Runtime Environment: which java platform is used and what version(last with Docker)
openHAB version: 3
Issue of the topic:
i create a schedule rule with a send command “OFF” to an item
when i try the rule with play button the rule work great
but it don’t start at the specified time
i verify the openhab log and the event log
there are no error in openhab log
in event log i don’t see the rule star but i see each time that i modify the schedule rule ( was saved each time)
i try multiple time, i modify schedule each time to report about 10 min later after unsuccessful try
but never work
@Wolfgang_S sometimes the solution is not too far and is a stupid thing
i don’t now why the time in docker is 2 hour minus from real time
i think i need to take a look at my server local time
i trust the time in my habpannel and don’t take care about nas time
i make some try with time needed - 2hrs and that work
for people who can have the same isue
you need to write your time zone in EXTRA_JAVA_OPTS " for me -Duser.timezone=Europe/Berlin"
means you just looked at the wrong point in time in the log resp. you did not wait long enough until the entry would have happened because of the wrong timezone ?
