I’m searching for a possibility to create a time based event within a rule execution. I’ll try to give an pseudo code which is hopefully self-explanatory:
rule "time based event"
Item openhab_item changed
if (openhab_item.state < 10) {
>>>>> send command to openhab at 08:00 a.m. <<<<<
} else {
>>>>> send command to openhab at 11:00 a.m. <<<<<
I’d like to schedule an action depending on rule execution. The only way I know right now is to create timer like this one:
createTimer(now.plusSeconds(10))
But I want to set a specific / absolute date and time. Is this possible with openHAB 1.8.3?
One approach would be to turn around the checked events. Trigger on a Cron and inside the rule check if item changed.
That way you will need two rules since you can’t combine two crons in a rule (atm ).
I’ll try coding of ModuloFS which seems to fit perfectly for my recommendations. Sometimes things could be so easy and I wonder why I’m not coming up with the idea of doing it this way
You need to move the actual_time definition inside the rule. As it is now actual_time will get set to the time that OH loaded and parsed the .rules file and never change.
If you do not plan on reusing timerload var in other rules, it too should be defined within the rule. One should scope vars and vals as tightly as possible.
Finally, this is probably just a typo but the rule is missing the end.
If @skidepp wants the command to be sent as close to 08:00 and 11:00 as possible the milliseconds should be processed instead of minutes. Otherwise, the command could be sent as late as 08:00:59 for example.
Personally, I think the code is clearer and more precise if one uses the methods built into now instead of manipulating epoc.
var Timer timer = null
var cmdTime = null
val eightAM = now.withTimeAtStartOfDay.plusHours(8) // 8am today
val elevenAM = now.withTimeAtStartOfDay.plusHours(11) // 11am today
if(open_hab.state < 10){
if(now.isBefore(eightAM)) cmdTime = eightAM
else cmdTime = eightAM.plusHours(24)
else {
if(now.isBefore(elevenAM)) cmdTime = elevenAM
else cmdTime = elevenAM.plusHours(24)
timer?.cancel // cancel timer if it exists
timer = createTimer(cmdTime, [|
// send command
timer = null
The above code will schedule the event to take place tomorrow if openhab_item changes after 8AM or 11AM.
Note that if you reload your .rules file or restart OH your timers will be lost. You may need a System started rule to recreate the Timer in this case, depending on your use case.
