I’m getting the following exception in my openhab.log. Maybe I’m not seeing the forest for all the trees, but I have no idea which Thing, Item, Link or Rule it is causing it. I can see it’s linked to a KNX Thing, but I have no idea which …
2022-04-06 19:57:05.486 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at tuwien.auto.calimero.device.ProcessCommunicationResponder.send(ProcessCommunicationResponder.java:256) ~[?:?]
at tuwien.auto.calimero.device.ProcessCommunicationResponder.write(ProcessCommunicationResponder.java:249) ~[?:?]
at tuwien.auto.calimero.device.ProcessCommunicationResponder.write(ProcessCommunicationResponder.java:226) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.sendToKNX(AbstractKNXClient.java:460) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.respondToKNX(AbstractKNXClient.java:439) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.lambda$8(DeviceThingHandler.java:297) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:148) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.sendGroupValueResponse(DeviceThingHandler.java:286) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.lambda$10(DeviceThingHandler.java:318) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.onGroupRead(DeviceThingHandler.java:312) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient$1.lambda$1(AbstractKNXClient.java:115) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.lambda$8(AbstractKNXClient.java:258) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
Can anybody help to steer me in the right direction?
