@chris thanks for the quick response. I’m confused as I had seen some threads talking about OH2 and secure inclusion with different locks happening. I thought I might just be on the brink with a new device. Interestingly I did notice something has happened, it managed to get further and identify the device successfully now, and it looks like the process may have been interrupted but in progress none the less. Including logs here if it helps, it did identify it as the BE469 in HABmin, which was the good news.
If there is a development version or test version, I’m happy to guinea pig myself and test it out. For me this is an important function of our smart home setup. I’m wrangling a bunch of other issues with setup as we just moved into a new home, but I’m happy to try and provide as much feedback and info as possible to help better the product.
2017-01-18 17:26:48.577 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 27: setupNetworkKey useSchemeZero=false
2017-01-18 17:26:53.923 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-18 17:26:53.923 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 17:26:59.227 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 1 attempts left!
2017-01-18 17:26:59.227 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 17:26:59.301 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 27: setupNetworkKey useSchemeZero=true
2017-01-18 17:26:59.301 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 27: Using Scheme0 Network Key for Key Exchange since we are in inclusion mode.
2017-01-18 17:26:59.509 [INFO ] [curityCommandClassWithInitialization] - NODE 27: Setting Network Key to real key after SECURITY_NETWORK_KEY_SET
2017-01-18 17:26:59.509 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 27: setupNetworkKey useSchemeZero=false
2017-01-18 17:26:59.680 [ERROR] [col.security.ZWaveSecureNonceTracker] - NODE 27: SECURITY_ERROR Device message contained nonce that is unknown to us, id=51.
2017-01-18 17:26:59.793 [WARN ] [mmandclass.ZWaveSecurityCommandClass] - NODE 27: payloadQueue was empty, returning!
2017-01-18 17:26:59.793 [ERROR] [ssage.ApplicationCommandMessageClass] - NODE 27: Unknown command class 0xffffff98
2017-01-18 17:27:04.684 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-18 17:27:04.684 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 17:27:05.123 [ERROR] [col.security.ZWaveSecureNonceTracker] - NODE 27: SECURITY_ERROR Device message contained nonce that was previously used, id=51.
2017-01-18 17:27:05.124 [ERROR] [ssage.ApplicationCommandMessageClass] - NODE 27: Failed to decrypt message out of Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 1B 16 98 81 AC 29 9E AF 0F 1F 71 73 1D 30 CE 33 0F FB D8 15 19 91 61 CE .
2017-01-18 17:27:31.151 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Initialising Thing Node...
This section starts to repeat itself over and over again.
2017-01-18 22:57:39.996 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 27: Node found
2017-01-18 22:57:40.287 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 27: setupNetworkKey useSchemeZero=false
2017-01-18 22:57:40.484 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Initialising Thing Node...
2017-01-18 22:57:48.909 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 0 attempts left!
2017-01-18 22:57:48.910 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:57:50.267 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 27: setupNetworkKey useSchemeZero=false
2017-01-18 22:57:50.332 [ERROR] [curityCommandClassWithInitialization] - NODE 27: SECURITY_ERROR Invalid state! Secure inclusion has not completed and we are not in inclusion mode. Aborting
2017-01-18 22:57:54.065 [INFO ] [ommandclass.ZWaveVersionCommandClass] - NODE 27: Command Class LOCK has version 0!
2017-01-18 22:58:08.048 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-18 22:58:08.048 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:58:13.577 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 1 attempts left!
2017-01-18 22:58:13.577 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:58:19.856 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 0 attempts left!
2017-01-18 22:58:19.857 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:58:25.387 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=27, callback=105, payload=1B 02 63 04
2017-01-18 22:58:30.861 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-18 22:58:30.861 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:58:36.345 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 1 attempts left!
2017-01-18 22:58:36.346 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:58:41.876 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 0 attempts left!
2017-01-18 22:58:41.876 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:58:47.389 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=27, callback=109, payload=1B 02 63 04
2017-01-18 22:58:53.660 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-18 22:58:53.660 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:58:59.203 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 1 attempts left!
2017-01-18 22:58:59.203 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:59:04.706 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 0 attempts left!
2017-01-18 22:59:04.706 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:59:10.214 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=27, callback=133, payload=1B 02 63 04
2017-01-18 22:59:15.726 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-18 22:59:15.727 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:59:21.232 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 1 attempts left!
2017-01-18 22:59:21.232 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:59:27.513 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 0 attempts left!
2017-01-18 22:59:27.514 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:59:33.018 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=27, callback=137, payload=1B 02 63 04
2017-01-18 22:59:38.492 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-18 22:59:38.493 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:59:44.002 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 1 attempts left!
2017-01-18 22:59:44.002 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:59:49.558 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 0 attempts left!
2017-01-18 22:59:49.561 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 22:59:55.049 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=27, callback=140, payload=1B 02 63 04
2017-01-18 23:00:47.061 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-18 23:00:47.061 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 23:00:52.583 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 1 attempts left!
2017-01-18 23:00:52.584 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 23:00:58.046 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Timeout while sending message. Requeueing - 0 attempts left!
2017-01-18 23:00:58.046 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 27: Got an error while sending data. Resending message.
2017-01-18 23:01:04.403 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 27: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=27, callback=16, payload=1B 02 63 04
2017-01-18 23:03:26.239 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 27: Node advancer: Retries exceeded at STATIC_VALUES
