I have a Schwaiger ZHS09 Door / Window Sensor, but in the XML node5.xml (8.1 KB) file it will be recognized as Vision ZD2102-5 instead. Is this information important and should the database be updated? And if so, how is this information entered? The manufacturer Schwaiger does not yet exist in the database.
The XML is built from what the device reports. There are lots of rebranded devices, and this one has several flavors. This should not be an issue, just confusing because you were expecting a different manufacturer. It should be the same device though, just sold in someone elses packaging.
