- Platform information:
- Hardware: openhabian, raspberry pi4
- OS: _openhabian 3
- Java Runtime Environment: default for openhabian
- openHAB version: 3
- Issue of the topic: Script will crash when it sends a command to an item
Code of script:
var settemp, bedroomtemp;
settemp = itemRegistry.getItem('Housetempset').getState();
bedroomtemp = itemRegistry.getItem('BedroomTempHumidity_BedroomTemperature').getState();
logger.info(('Checking Bedroom Heat'));
if (bedroomtemp < settemp - 8) {
events.sendCommand('BedroomHeater_BedroomHeater', 'on');
logger.info((['current temp: ',bedroomtemp,'- Turning ON, Setting to: ',settemp].join('')));
if (bedroomtemp > settemp - 3) {
logger.info((['current temp: ',bedroomtemp,'- Turning OFF, Setting to: ',settemp].join('')));
log file crash report:
2021-06-12 09:09:56.179 [INFO ] [org.openhab.rule.bedroomcold ] - Checking Bedroom Heat
2021-06-12 09:09:56.192 [WARN ] [e.automation.internal.RuleEngineImpl] - Fail to execute action: script
java.lang.IllegalArgumentException: The argument 'state' must not be null.
at org.openhab.core.events.AbstractEventFactory.checkNotNull(AbstractEventFactory.java:115) ~[?:?]
at org.openhab.core.items.events.ItemEventFactory.assertValidArguments(ItemEventFactory.java:401) ~[?:?]
at org.openhab.core.items.events.ItemEventFactory.createStateEvent(ItemEventFactory.java:250) ~[?:?]
at org.openhab.core.items.events.ItemEventFactory.createStateEvent(ItemEventFactory.java:266) ~[?:?]
at org.openhab.core.automation.module.script.internal.defaultscope.ScriptBusEvent.postUpdate(ScriptBusEvent.java:154) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$1199$\^eval\_$cu1$restOf.:program(<eval>:10) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:655) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:513) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:527) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:456) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:413) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:409) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.eval(NashornScriptEngine.java:162) ~[jdk.scripting.nashorn:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:264) ~[java.scripting:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1179) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1031) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1047) [bundleFile:?]
at org.openhab.core.automation.rest.internal.RuleResource.runNow(RuleResource.java:314) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor184.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) [bundleFile:1.0.9]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) [bundleFile:1.0.9]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) [bundleFile:1.0.9]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) [bundleFile:1.0.9]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) [bundleFile:1.0.9]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) [bundleFile:1.0.9]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:267) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:216) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:301) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:220) [bundleFile:1.0.9]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) [bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:276) [bundleFile:1.0.9]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
I got stuck trying to understand what is happening here. It suceeds on an off state, but crashes if it runs the âevents.sendCommand(âBedroomHeater_BedroomHeaterâ, âonâ);â line. I originally designed it with blockly. If I run it from the code screen, it fails immediately and gives: âTypeError: Cannot read property âgetBlocksâ of undefinedâ
Any help appreciated, I am going to start over and see if i can turn anything on/off and go from there.
Thank you,
Justin Rowell
