Hi there, I’ve been playing with A Rasp PI and a Tasmota flashed chinese GarageDoor opener and as a beginner am struggling with rules etc.
I’m running 2.4 image as everytime I deployed 2.5 it completed the install but had no Paper UI or Basic UI, but that’s not my man query;
I have successfully got the opener working via MQTT 2.4 (which also deletes the binding everytime you restart OpenHab and needs to be added again.) but I’m struggling to make the switch operate as momentary, manual switching works fine.
I’ve created a rule as below but it doesn’t seem to trigger, this rule is in rules directory and I see it successfully load in the logs
Item Garage_Door_Status changed from OFF to ON
// createTimer(now.plusSeconds(2))
Garage_Door.sendCommand(OFF)
2020-04-09 01:30:13.408 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘garage.rules’
2020-04-09 01:30:14.693 [ome.event.ItemCommandEvent] - Item ‘mqtt_topic_c80ac941_GarageDoor’ received command OFF
2020-04-09 01:30:14.707 [nt.ItemStatePredictedEvent] - mqtt_topic_c80ac941_GarageDoor predicted to become OFF
2020-04-09 01:30:14.738 [vent.ItemStateChangedEvent] - mqtt_topic_c80ac941_GarageDoor changed from ON to OFF
2020-04-09 01:30:14.862 [vent.ItemStateChangedEvent] - mqtt_topic_c80ac941_Garage_Door_Switch_Status changed from ON to OFF
2020-04-09 01:30:18.879 [ome.event.ItemCommandEvent] - Item ‘mqtt_topic_c80ac941_GarageDoor’ received command ON
2020-04-09 01:30:18.887 [nt.ItemStatePredictedEvent] - mqtt_topic_c80ac941_GarageDoor predicted to become ON
2020-04-09 01:30:18.904 [vent.ItemStateChangedEvent] - mqtt_topic_c80ac941_GarageDoor changed from OFF to ON
Question is the something I need to do to have rules active?
