Hi, I am trying to run some scripting files whcih can be stored to the static HTML folder as I am trying to add some modules to openhab so that I can use it as virtual asssiatant. What are the supported languages ?
Bikash
Bikash
Hi @hmerk thanks for the response. I have gone through that. But as far as I learned that works fine for events and triggers and again has to be in rules. but my requirement is a bit different. I want to access Database from the static html pages whci can’t be done by browser JS codes. For that I am looking for some scripting language which can run with OpenHAB and I wil get spared from running any other server parallel to OpenHAB whcih obviously will work and will work for my purpose. But I am looking for some native support on OpenHAB so that other users can also use the codes without any hassle.
***I am trying to add some modules like google map, gmail. facebook, financial calculations integration with OpenHAB so that it can also be used as a virtual assistant.
Bikash
