Hello OH friends,
I’m running OH3.1 on a rPi3 since several weeks without issue. This morning I had a power loss and after booting up, I get many many failures :
- Failed to start Network Time Synchronization
- Failed to start Entropy daemon using the HAVEGE algorithm
- Failed to start Update UTMP about system boot shutdown
- Failed to start dphys-swapfile - set up, mount/umount and delete a swap file
- Failed to start Mosquitto MQTT v3.1 Broker
Then, at the login screen, here is what I see when I enter my credentials :
Linux openHABianDevice 5.10.17-v7+ #1421 SMP Thu May 27 13:59:01 BST 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Sep 7 08:59:17 2021 from 192.168.2.17
mktemp: failed to create file via template '/tmp/tmp.XXXXXXXXXX': Read-only file system
/usr/local/bin/FireMotD: line 205: : No such file or directory
/usr/local/bin/FireMotD: line 206: : No such file or directory
rm: missing operand
Try 'rm --help' for more information.
/usr/local/bin/FireMotD: line 341: : No such file or directory
/usr/local/bin/FireMotD: line 342: : No such file or directory
/usr/local/bin/FireMotD: line 343: : No such file or directory
/usr/local/bin/FireMotD: line 344: : No such file or directory
/usr/local/bin/FireMotD: line 347: : No such file or directory
rm: missing operand
/usr/local/bin/FireMotD: line 375: : No such file or directory
/usr/local/bin/FireMotD: line 376: : No such file or directory
/usr/local/bin/FireMotD: line 377: : No such file or directory
/usr/local/bin/FireMotD: line 378: : No such file or directory
/usr/local/bin/FireMotD: line 379: : No such file or directory
rm: missing operand
/usr/local/bin/FireMotD: line 387: : No such file or directory
/usr/local/bin/FireMotD: line 388: : No such file or directory
rm: missing operand
/usr/local/bin/FireMotD: line 395: cannot create temp file for here-document: Re ad-only file system
/usr/local/bin/FireMotD: line 407: cannot create temp file for here-document: Re ad-only file system
/usr/local/bin/FireMotD: line 408: cannot create temp file for here-document: Re ad-only file system
/usr/local/bin/FireMotD: line 413: : No such file or directory
/usr/local/bin/FireMotD: line 414: : No such file or directory
/usr/local/bin/FireMotD: line 415: : No such file or directory
/usr/local/bin/FireMotD: line 416: : No such file or directory
/usr/local/bin/FireMotD: line 417: : No such file or directory
/usr/local/bin/FireMotD: line 418: : No such file or directory
rm: missing operand
/usr/local/bin/FireMotD: line 425: cannot create temp file for here-document: Re ad-only file system
/usr/local/bin/FireMotD: line 427: cannot create temp file for here-document: Re ad-only file system
/usr/local/bin/FireMotD: line 429: cannot create temp file for here-document: Re ad-only file system
/usr/local/bin/FireMotD: line 434: : No such file or directory
/usr/local/bin/FireMotD: line 435: : No such file or directory
/usr/local/bin/FireMotD: line 436: : No such file or directory
/usr/local/bin/FireMotD: line 437: : No such file or directory
/usr/local/bin/FireMotD: line 438: : No such file or directory
/usr/local/bin/FireMotD: line 439: : No such file or directory
rm: missing operand
/usr/local/bin/FireMotD: line 446: cannot create temp file for here-document: Re ad-only file system
/usr/local/bin/FireMotD: line 448: cannot create temp file for here-document: Re ad-only file system
/usr/local/bin/FireMotD: line 450: cannot create temp file for here-document: Re ad-only file system
/usr/local/bin/FireMotD: line 454: : No such file or directory
/usr/local/bin/FireMotD: line 455: : No such file or directory
/usr/local/bin/FireMotD: line 456: : No such file or directory
/usr/local/bin/FireMotD: line 457: : No such file or directory
/usr/local/bin/FireMotD: line 458: : No such file or directory
/usr/local/bin/FireMotD: line 459: : No such file or directory
rm: missing operand
/usr/local/bin/FireMotD: line 498: : No such file or directory
/usr/local/bin/FireMotD: line 499: : No such file or directory
rm: missing operand
/usr/local/bin/FireMotD: line 518: : No such file or directory
/usr/local/bin/FireMotD: line 519: : No such file or directory
/usr/local/bin/FireMotD: line 520: : No such file or directory
rm: missing operand
############### openHABianDevice ############################################
## Ip = 169.254.220.15
## Release = Raspbian GNU/Linux 10 (buster)
## Kernel = Linux 5.10.17-v7+
## Platform = Raspberry Pi 3 Model B Rev 1.2
## Uptime = ${UptimeDays} day(s). ${UptimeHours}:${UptimeMinutes}:${UptimeSec onds}
## CPU Usage = ${CpuUsageAverage}% avg over ${CpuUsageCpuCount} cpu(s) (${CpuUsa geCoreCount} core(s) x ${CpuUsageSocketCount} socket(s))
## CPU Load = ${CpuLoad}
## Memory = Free: ${MemFreeGB}GB (${MemFreePerc}%), Used: ${MemUsedGB}GB (${M emUsedPerc}%), Total: ${MemTotalGB}GB
## Swap = Free: ${SwapFreeGB}GB (${SwapFreePerc}%), Used: ${SwapUsedGB}GB ( ${SwapUsedPerc}%), Total: ${SwapTotalGB}GB
## Root = Free: ${DiskRootFreeGB}GB (${DiskRootFreePerc}%), Used: ${DiskRoo tUsedGB}GB (${DiskRootUsedPerc}%), Total: ${DiskRootTotalGB}GB
## Updates = 38 apt updates available.
## Sessions = ${SessionCount} session(s)
## Processes = ${ProcessCount} running processes of ${ProcessMax} maximum proces ses
_ _ _ ____ _
___ ___ ___ ___ | | | | / \ | __ ) (_) ____ ___
/ _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \ | | / _ \ / _ \
| (_) | (_) | __/| | | || _ | / ___ \ | |_) )| || (_) || | | |
\___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/ |_| \__|_||_| | |
|_| 3.1.0 - Release Build
Looking for a place to get started? Check out 'sudo openhabian-config' and the
documentation at https://www.openhab.org/docs/installation/openhabian.html
The openHAB dashboard can be reached at http://openHABianDevice:8080
To interact with openHAB on the command line, execute: 'openhab-cli --help'
openhabian@openHABianDevice:~ $
Then if I try to update OH3, I still get the read-only failures :
openhabian@openHABianDevice:~ $ sudo apt-get update
[sudo] password for openhabian:
Ign:1 http://davesteele.github.io/comitup/repo comitup InRelease
Err:2 http://davesteele.github.io/comitup/repo comitup Release
Could not open file /var/lib/apt/lists/partial/davesteele.github.io_comitup_repo_dists_comitup_Release - open (30: Read-only file system) [IP: 185.199.110.153 80]
Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
Err:3 https://deb.nodesource.com/node_14.x buster InRelease
Couldn't create temporary file /tmp/apt.conf.QlPDeP for passing config to apt-key
Ign:4 http://archive.raspberrypi.org/debian buster InRelease
Hit:5 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Err:5 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Couldn't create temporary file /tmp/apt.conf.hbT1iX for passing config to apt-key
Ign:6 http://raspbian.raspberrypi.org/raspbian buster InRelease
Err:7 http://archive.raspberrypi.org/debian buster Release
Could not open file /var/lib/apt/lists/partial/archive.raspberrypi.org_debian_dists_buster_Release - open (30: Read-only file system) [IP: 46.235.227.39 80]
Err:8 http://raspbian.raspberrypi.org/raspbian buster Release
Could not open file /var/lib/apt/lists/partial/raspbian.raspberrypi.org_raspbian_dists_buster_Release - open (30: Read-only file system) [IP: 93.93.128.193 80]
Reading package lists... Done
N: Ignoring file 'openhab.liste' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
W: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
W: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
W: chown to _apt:root of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system)
W: chmod 0700 of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system)
W: Not using locking for read only lock file /var/lib/apt/lists/lock
W: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.Zu5uSz - IsAccessibleBySandboxUser (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.0o7DyS - IsAccessibleBySandboxUser (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.PCaJfb - IsAccessibleBySandboxUser (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.eJaTWt - IsAccessibleBySandboxUser (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.9zwQDM - IsAccessibleBySandboxUser (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/davesteele.github.io_comitup_repo_dists_comitup_InRelease - PrepareFiles (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/davesteele.github.io_comitup_repo_dists_comitup_Release - PrepareFiles (30: Read-only file system)
E: The repository 'http://davesteele.github.io/comitup/repo comitup Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Problem unlinking the file /var/lib/apt/lists/partial/deb.nodesource.com_node%5f14.x_dists_buster_InRelease - PrepareFiles (30: Read-only file system)
W: chown to _apt:root of file /var/lib/apt/lists/deb.nodesource.com_node%5f14.x_dists_buster_InRelease failed - Item::QueueURI (30: Read-only file system)
W: chmod 0600 of file /var/lib/apt/lists/deb.nodesource.com_node%5f14.x_dists_buster_InRelease failed - Item::QueueURI (30: Read-only file system)
W: chown to root:root of file /var/lib/apt/lists/deb.nodesource.com_node%5f14.x_dists_buster_InRelease failed - 400::URIFailure (30: Read-only file system)
W: chmod 0644 of file /var/lib/apt/lists/deb.nodesource.com_node%5f14.x_dists_buster_InRelease failed - 400::URIFailure (30: Read-only file system)
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_14.x buster InRelease: Couldn't create temporary file /tmp/apt.conf.QlPDeP for passing config to apt-key
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.raspberrypi.org_debian_dists_buster_InRelease - PrepareFiles (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/openhab.jfrog.io_artifactory_openhab-linuxpkg_dists_stable_InRelease - PrepareFiles (30: Read-only file system)
W: chown to _apt:root of file /var/lib/apt/lists/openhab.jfrog.io_artifactory_openhab-linuxpkg_dists_stable_InRelease failed - Item::QueueURI (30: Read-only file system)
W: chmod 0600 of file /var/lib/apt/lists/openhab.jfrog.io_artifactory_openhab-linuxpkg_dists_stable_InRelease failed - Item::QueueURI (30: Read-only file system)
W: chown to root:root of file /var/lib/apt/lists/openhab.jfrog.io_artifactory_openhab-linuxpkg_dists_stable_InRelease failed - 400::URIFailure (30: Read-only file system)
W: chmod 0644 of file /var/lib/apt/lists/openhab.jfrog.io_artifactory_openhab-linuxpkg_dists_stable_InRelease failed - 400::URIFailure (30: Read-only file system)
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease: Couldn't create temporary file /tmp/apt.conf.hbT1iX for passing config to apt-key
W: Problem unlinking the file /var/lib/apt/lists/partial/raspbian.raspberrypi.org_raspbian_dists_buster_InRelease - PrepareFiles (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.raspberrypi.org_debian_dists_buster_Release - PrepareFiles (30: Read-only file system)
E: The repository 'http://archive.raspberrypi.org/debian buster Release' no longer has a Release file.
W: Problem unlinking the file /var/lib/apt/lists/partial/raspbian.raspberrypi.org_raspbian_dists_buster_Release - PrepareFiles (30: Read-only file system)
E: The repository 'http://raspbian.raspberrypi.org/raspbian buster Release' no longer has a Release file.
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (30: Read-only file system)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (30: Read-only file system)
Please help me, I have over hundreds and hundreds of hours through OH1-2-3 over the past years. I have a SD backup of last July but I really wish to repair my setup instead.
What logs or what info do you need so you can help me?
Thanks in advance!
