Hi all this is quite of topic but maybe someone can help.
My OH on raspberry is not starting anymore (or rather starting but is unreachable)
I verified that the SD is somehow write protected so I guess at startup the OS is trying to wrote some files and fails.
I can see all files and I even did a backup using dd but when I rewrite it I am stuck in the same situation.
Now the two questions:
- Anyone knows how I can reenable write /reuse this sd?
- Supposing the sd is damaged and I take a new one will it be enough to simply copy the files there (rather then rewriting the image on it). I am asking since, I suppose, that rewriting the verbatim image on the new SD might just recreate the problem on the new sd.
Hope having written not too many stupid stuff tx for the help
update: running fsck from a linux pc tells me superblock is damaged. So I guess SD corruption,
So, again more a linux then OH Qn, will a dd with a fresh raspbian image reset it?
