I am a newbee here and i am wondering if there is a way to connect the Elro K1 hub (binding SF40GA) to the openhab software. The Elro K1 is a hub which connects my android software using wifi to the 868 Mhz Elro things like outlet switches, smoke and heat detectors. It is also known as the gs188a binding from siterwel electronics CO
Hi I have the same Elro HUB at home and I’m looking for the same answer
If you are still looking, and up for some testing, I created a first version of a binding. You can find more info here.
