Hi
I’m using OpenHab2 on my raspberry pi3.
I have created account on cloud for connect my iphone by internet.
When I’m inside my LAN, I use only the IP for connecting my iphone.
My questions:
can I configure a secure login when I’m on my LAN with login and password?
can I create different account for different function (sitemap different for different users)
Yes. You can either run a local instance of the openHAB Cloud software or configure a reverse proxy using NGINX or Apache. Then configure your network on your hosts and/or router to not allow access to the openHAB ports on that machine.
No you cannot.
There is work started but stalled to add authentication to OH. It’s not clear when/if it will be implemented and it’s pretty certain the RBAC (Role Based Access) type controls will not be part of the initial release.
Hi
thanks a lot for reply
I have installed apache for my web server (same information of openhab, but written in php/html).
Could you suggest how I have to do?
Is better NGINX for openhab? so to have separeted my web server from openhab.
