Securing Openhab with free ssl Let's Encrypt Certificates
Not if they are all in the same private network
I would also like to know, the documentation suggests using an nginx proxy. But using SSL on Jetty should be working as well, but I can’t seem to locate the keystore (or myKeystore as the jetty.config.xml suggests).
haven’t tried it but I found : Jetty Documentation :: Eclipse Jetty
what’s wrong with the self signed certs ? :slight_smile:
The original post was written more than 2 years ago when OH2 was using Jetty 8
Now, we have Jetty 9 so the configs are different
Jetty 8 related: The Eclipse Jetty Project :: Eclipse Jetty
Jetty 9 related: Jetty Documentation :: Eclipse Jetty
with some adaptation you can make it work (apply Let’s Encrypt Certs to OH2 running Jetty 9)
Thanks. Need to try it some day.
For those trying to replace the self-signed key and certificate in OH2.5 the steps above need a little modification. This is what has worked for me. NB. OH is designed with few security layers in place and it uses a default password “openhab” both for the keystore and the key itself. The name of the key has to be “mykey” unless you change other config files. Feel free to figure out how to change it, but do not expect much in terms of increasing the overall security. The only advantage of using a proper certificate, like LE in this case, is to avoid browser warnings and/or having to install CAs into them, while at least having browser-OH traffic encrypted. While this is useful and important part of security hygiene, it is also merely a drop in the ocean in terms of home automation security, which is still very, very poor no matter the provider nowadays. Rant end.
openssl pkcs12 -nodes -passout pass:openhab \
        -inkey YOUR_PRIVATE_KEY \
        -in YOUR_CERTIFICATE \
        -export -name mykey \
        -out SOMEWHERE/oh.pkcs12
keytool -delete -alias mykey -deststorepass openhab \
        -keystore /var/db/openhab2/userdata/etc/keystore
keytool -importkeystore -srcstorepass openhab \
        -srckeystore SOMEWHERE/oh.pkcs12 \
        -srcstoretype PKCS12 -deststoretype jks \
        -alias mykey -destalias mykey -deststorepass openhab \
        -destkeystore /var/db/openhab2/userdata/etc/keystore
@mstormi would be great to implant this into openHABian. Any chances?
Apart from that I don’t understand what this is about and won’t dig gazillions of messages just to understand your question in the first place, chances are right as high as chances you implement this yourself are.
BTW in openHABian use nginx rather than to run jetty on SSL. nginx automatically uses LetsEncrypt certs when you install from the menu.
And stop pinging people please.
How to ask a good question / Help Us Help You - Tutorials & Examples - openHAB Community
:+1:
My installation Ubuntu 22.04 and OpenHab 3 with a domain name.
I solved the issue with the following way.
The principle being to replace the default keystore file (/var/lib/openhab/etc) generated by openhab for the installation and giving a certificate for openhab.org.
No need to modify jetty.xml.
Assumption : you already have a LetsEncrypt certificate into /etc/letsencrypt/live/mydomain.be
First step : need to add all .pem files to a PKCS 12 archive. We do this with the OpenSSL tool with the following command.
openssl pkcs12 -export \
	 -in /etc/letsencrypt/live/mydomain.be/cert.pem \
	 -inkey /etc/letsencrypt/live/mydomain.be/privkey.pem \
	 -out /tmp/mydomain.be.p12 \
	 -name mydomain.be \
	 -CAfile /etc/letsencrypt/live/mydomain.be/fullchain.pem \
	 -caname "Let's Encrypt Authority X3" \
	 -password pass:openhab
Change mydomain.be with your own DNS name.
IMPORTANT : password must be openhab otherwise it will not work !!! (that’s the password used by openhab to generate its keystore file and used later on)
Second step: is to import the certificates into a .keystore file.
keytool -importkeystore \
	-destkeypass openhab \
	-deststoretype pkcs12 \
	-srckeystore /tmp/mydomain.be.p12 \
	-srcstoretype PKCS12 \
	-destkeystore /tmp/mydomain.be.keystore \
	-alias mydomain.be
Third Step : You can now copy the keystore at location /tmp/mydomain.be.keystore in /var/lib/openhab/etc.
mv /tmp/mydomain.be.keystore /var/lib/openhab/etc/keystore
This will replace the default keystore file by the one generated from the letsencrypt certificate.
Something interesting could be to check that the new keystore file is correct with :
keytool -list -v -keystore /var/lib/openhab/etc/keystore >output_filename.txt
(it will request the password = openhab)
View the Output File :
nano /var/lib/openhab/etc/output_filename.txt
note : no error message should be present into this output file.
Last step : make a script to cron it in order to update the certificate when it is renewed by letsencrypt.
