To answer the original question:
As far as I can tell, wildcards are not supported.
I’m also having problems with the whitelist.
I have created the folder in /etc/openhab2/misc and the file in it, with CRLF endings, but it still says it is not contained in the whitelist, these are rather simple bash scripts mainly…
Ps.: I have changed the ending to LF and it started to work, even without a restart funny…
How can I update this page to add the extra information?
And for clarity, what format does the exec.whitelist need?
Does it require a line feed after each command, or it is CSV style?
There is a link at the bottom of the page that will open the file in GitHub where you can edit and submit a PR. I’m pretty sure that link is working correctly again.
solved issue also for me. did this:
I had to reboot openHAB and then the white list error message returned. It worked before the reboot and I didn’t change anything else.
I then simply edited the white list in notepad++ and removed all LF symbols. Saved the new file and the exec command started working again.
I dont think the problem is with converting from CRLF to LF and back.
What needs to be done in order for the commands in exec.whitelist to be executed, at least that works for me(tried several times)
Shutdown openhab2
put your command in the exec.whitelist and ADD any character at the end and save. i.e.
/usr/local/bin/command.sh %2$sX
start openhab
open exec.whitelist ( i did it with vi)
remove the extra character at the end and save.
suddenly the exec is able to execute again. This works until the next time you need to restart openhab2.
The same process needs to be repeated. Frankly its a bit of the PITA.
I don’t think you need to add and remove anything. Just save the file again after a restart. Depending on the editing tool maybe something needs to be added, anything, and immediately removed in order to force the editor to save.
So sequence is:
I did it with visual studio code this time as misc folder and whitelist are listed there. Its the quickest and easiest way for me to do the save.
The documentation doesn’t tell exactly where the file misc/exec.whitelist
should be located.
Is it supposed to be $OPENHAB_CONF/misc/exec.whitelist
EDIT: it appears it is indeeed $OPENHAB_CONF/misc/exec.whitelist
For security reasons all commands need to be whitelisted. Allowed commands need to be added to the
misc/exec.whitelist
file in the configuration directory
That looks clear to me.
I added my commands to $OPENHAB_CONF/misc/exec.whitelist but still get the warning “it is not contained in whitelist”. The openhab2 service was restartet after adding the commands to white list.
I use a hughe amount of commands (with different parameters).
I want to revert to version 2.5.1. There for i downgraded to openhab 2.5.1 with cleaning cache.
openhab-cli info returns Version: 2.5.1 (Build)
But in karaf console there is still the Exec binding 2.5.2.
How to revert to Exec binding 2.5.1?
Just save the whitelist again. No need for any changes but a save must be done after restart.
Do what happens for people that auto restart openhab2 once a month?
Do we now need to create something to touch
the file after a restart?
I have the misc/exec.whitelist in OpenHAB’s conf directory and nothing of the above helped. Still I get the messages it’s not whitelisted and cannot (and is not) be executed.
That’s starting to become frustrating.
I experience the same issues. Nothing seems to work. Does anybody know where I can download the 2.5.1 version?
Getting in over my head here, but I see something strange even though it’s working for me. https://github.com/openhab/openhab-addons/blob/2.5.x/bundles/org.openhab.binding.exec/src/main/java/org/openhab/binding/exec/internal/ExecWhitelistWatchService.java#L60
…has two messages, a warning and a debug messge. I never see the debug “Updated command whitelist”, even though I have done log:set DEBUG org.openhab.binding.exec.internal
and log:set DEBUG org.openhab.binding.exec
in the console. Is this the correct log setting to view the result of logger.debug("Updated command whitelist: {}", commandWhitelist);
When I modify the file through vim, I always see “Cannot read whitelist file, exec binding commands won’t be processed” warning message on save.
I don’t see any message when I touch the file.
Having said that, it works for me; if I tweak a line in the file, I get the “…but it is not contained in whitelist” error message, and if I tweak it back to what it should be, it then works.
I don’t know if this is any sort of clue as to why it’s working for some and not others.
Edit: to clarify, I do have to touch the file after a restart for the whitelist to be loaded. I’ve setup a cron entry to do this every few mins for now. Couldn’t figure out a way with systemd unfortunately. A resolution for this would be helpful.
If the first line of the try
throws, you won’t ever see the DEBUG…
try {
Files.lines(path).forEach(commandWhitelist::add);
} catch (IOException e) {
logger.warn("Cannot read whitelist file, exec binding commands won't be processed: {}", e.getMessage());
This is very badly written for debugging.
Hi, thanks @namraccr It’s odd that I never see the debug message, even though it’s working for me - that’s the bit I don’t understand. Files.lines(path).forEach(commandWhitelist::add);
must be completing OK for it to be working?
Ok, this seems to be a vim thing - I don’t see the “Cannot read whitelist file” when using nano. Maybe vim deletes it (triggering the warning) and moves a tmp file into place or something?
So this is a red herring I think. Doesn’t quite explain why I never see the “Updated command whitelist” though.
Edit: It appears the following is needed for the “Updated command whitelist” to show in the log:
log:set DEBUG org.eclipse.smarthome.core.service.AbstractWatchService
…and might be a bug.
Hi @namraccr,
could you please give a hint of where to get the 2.5.1 jar from to install the previous version? I’m having much trouble and can’t get it to work.
Thanks!
