Hi all,
is it possible to launch HABPanel directly into one of the configurations listed under “Current storage configuration”.
The use case is: I have two different configs, one for private use and one for guest use. When I’m away I want to boot the panel directly into guest configuration.
I know it is possible select the view (/panel/#/view/start e.g.) but I want to pre-select config and view of that config.
No I didn’t.
