representing the Semantic features of an openHAB Item to Blockly
and
a calculator for humidity
Beginner with bad English skills. Sorry.
Error messages (and solutions?) Are expressly desired.
Blocks
Parents of Item
return equipment and location as a Item
Type of …
return a String
Whether the Item is a …
return a Boolean
Calculator for air humidity
Calculated based on this Function absolute air humidity, dew point and vapor pressure.
Input only in Units % and °C. The Unit for Output Is included.
Changelog
Version 0.3
- Fine-tuning code
Version 0.2
- Optical changes
Version 0.1
- first published version
Ressourcen
-requires JavaScript (ECMAScript 2022+/GraalJS)
uid: Semantic_Humidity
tags: []
props:
parameters: []
parameterGroups: []
timestamp: May 31, 2025, 5:20:40 PM
component: BlockLibrary
name: Semantic & Humidity
slots:
blocks:
- component: BlockType
args0:
- name: optSemantic
options:
- - Equipment
- equipment
- - Location
- location
type: field_dropdown
- align: right
type: input_value
colour: 0
helpUrl: https://openhab.github.io/openhab-js/items.ItemSemantics.html
message0: semantic %1 parent of item %2
output: ""
tooltip: equipment/location of Item. In for_each use get_name_of_item if
necessary
type: SemanticItem
slots:
code:
- component: BlockCodeTemplate
template: items.getItem({{input:semanticItem}}).semantics.{{field:optSemantic}}
toolbox:
- component: PresetInput
shadow: true
type: oh_item
args0:
- name: optSemantic
options:
- - Equipment
- equipmentType
- - Location
- locationType
- - Point
- pointType
- - Property
- propertyType
- - Semantic
- semanticType
- align: right
type: input_value
colour: 165
message0: semantic %1 type of item %2
output: String
tooltip: Type of equipment/location/point/property/semantic. Return string
type: SemanticString
slots:
code:
toolbox:
shadow: true
type: oh_item
args0:
- name: optSemantic
options:
- - Equipment
- isEquipment
- - Location
- isLocation
- - Point
- isPoint
- align: right
type: input_value
colour: 210
message0: semantic is %1 ? of item %2
output: Boolean
tooltip: Is Equipment/Location/Point? Return Boolean
type: semanticBoolean
slots:
code:
toolbox:
shadow: true
type: oh_item
args0:
- name: Ausgabe
options:
- - Humidity g/m3
- af
- - dew point °C
- tt
- - vapor pressure hPa
- dd
- name: relativ
type: input_value
- align: right
type: input_value
colour: 60
helpUrl: https://www.smarthome-tricks.de/iobroker-scriptsammlung/taupunkt-berechnen/
lastDummyAlign0: right
message0: "%1 from rel. humidity % %2 and temperature °C %3"
output: Number
tooltip: calculates values for humidity
type: Humidity
slots:
code:
template: "{{utility:taupunkt}}({{input:relativ}},{{input:temp}}).{{field:Ausga\
be}}"
toolbox:
fields:
NUM: 50
shadow: true
type: math_number
fields:
NUM: 15
shadow: true
type: math_number
utilities:
- component: UtilityFunction
code: >
function {{name}}(rel ,temp) {
// Block Humidity
var r = parseFloat(rel);
var t = parseFloat(temp);
var mw = 18.016; var gk = 8314.3;
var t0 = 273.15; var tk = t + t0;
var a, b;
if (t >= 0) {
a = 7.5; b = 237.3;
} else if (t < 0) {
a = 7.6; b = 240.7;
var sdd = 6.1078 * Math.pow(10, (a*t)/(b+t));
var dd = sdd * (r/100);
var af = Math.pow(10,5) * mw/gk * dd/tk;
var v = Math.log(dd/6.1078)/ 2.302585092994046;
var tt = (b*v) / (a-v);
return { tt: tt.toFixed(4) + ' °C', af: af.toFixed(4) + ' g/m³', dd: dd.toFixed(4) + ' hPa'};
