My current semantic model looks like that:
So I have a Living Area which is logically split into Kitchen, Dining and Living-room. I have 3 thermostats at the Radiators and 2 window sensors.
I now want to add for each ob the 3 sub-rooms a Point with desired temperature, this will then be used in a rule to set the temperature on the thermostats depending on the windows and maybe other factors. I know how to do that, but I also want those 3 Points to be in a Group something like:
Living>Temperature>Temperature Kitchen
Living>Temperature>Temperature Dining
Living>Temperature>Temperature Livingroom
This has two reasons:
- In the semantic model it would look cleaner if the 3 are grouped.
- I want to control all 3 of them simultaneously, but also be able to change them individually. In Openhab 2 I created a Group with aggregation for that, but this seems not possible in the semantic model.
Does anyone have an Idea on how to do this nicely? I really like to have that in the semantic model. I have found a Way to just create the required Items, but then they do not show up in the semantic model.
