semanticHomeMenu for openHAB 4 - Discussions
Ah, sorry, overseen the group memberships. Sorry, but this does not look right.
The group
Group    gEquipFamilyRoomLights         "Family Room Lights"          <material:lightbulb>                (gLocMainFloorFamilyRoom)      ["Lightbulb"]
needs to have a different Tag, otherwise the brightness controls will not be seen.
Please change Tag and Metadata to
Group    gEquipFamilyRoomLights         "Family Room Lights"          <material:lightbulb>                (gLocMainFloorFamilyRoom)      ["DimmableLight"] {uiSemantics="uiSemantics"[preposition=" in the", equipment="Ceiling Light", location="Bathroom"}
The Item
Dimmer              MainFloor_FirePlaceLights_Dimmmer                  "Fire Place Lights"                       <light>             (gEquipFamilyRoomLights)        ["Control","Light"]           {channel="mqtt:homie300:Queen:dimmer-4ab35c1:dimmer#dimmer", OccupancyEvent = "Switch"}
is member of
Therefore, the naming needs to be
Dimmer              gEquipFamilyRoomLights_brightness               "Fire Place Lights"                       <light>             (gEquipFamilyRoomLights)        ["Control","Light"]           {uiSemantics="uiSemantics"[preposition=" in the", equipment="Ceiling Light", location="Bathroom"],channel="mqtt:homie300:Queen:dimmer-4ab35c1:dimmer#dimmer", OccupancyEvent = "Switch"}
Please note, you can have as many lights in a location as you wish, but each light needs it’s own equipment group and the Points (Items) in the group follow this naming:
EquipmentGroupName + "_" + ControlType[switch/brightness/colorTemperature/color]
Hi.
Look at his gitbub: GitHub - hmerk/semanticHomeMenu
There are all “redme files” + demo.items to help you.
And yes, you must follow the naming of the items.
BR
After reviewing the Semantic Model docs - I don’t see DimmableLight in the list of points/properties. Has this list changed?
Do equipment group names have to follow the naming convention of the individual items? Can I create a group to contain all the lights and then add that to the equipment group if I want to control them together?
No, as written in the docs, DimmableLight is a non semantic tag to be entered manually.
The following might make the naming it a bit clearer.
Never tried before, but just proofed it working, see following screenshots
Here is what I put together from the posts here and example files on github with the help of Gemini and Claude. Does this look right?
semanticUI Integration Key Findings
Overview
The semanticUI has specific requirements and conventions that differ from openHAB’s core semantic model in several important ways. This document captures key findings about how to properly integrate with semanticUI.
Location and Equipment Groups
Location Structure
  • Uses standard openHAB location hierarchy: Building → Floor → Room
  • Locations should have proper semantic tags (e.g., [“Room”], [“Kitchen”])
  • Location groups follow format: gLoc[LocationName]
Equipment Groups
Two approaches are possible:
  1. Individual Equipment Groups
    • Each device gets its own equipment group
    • Must be tagged with [“Lightbulb”]
    • Requires uiSemantics metadata
    Group    KitchenUnderCabinet    "Under Cabinet"    (gEquipKitchenLights)    ["Lightbulb"]
    {uiSemantics="uiSemantics"[preposition="in the", equipment="Under Cabinet Lights", location="Kitchen"]}
  2. Consolidated Equipment Groups
    • Single group contains multiple related devices
    • More efficient for devices that are typically controlled together
    • Still requires proper tagging and metadata
    Group    gEquipKitchenLights    "Kitchen Lights"    (gLocKitchen)    ["Lightbulb"]
UI Semantics Metadata
  • Required format: {uiSemantics="uiSemantics"[preposition="...", equipment="...", location="..."]}
  • Prepositions affect display (“in the”, “on the”)
  • Equipment name is used for display and grouping
  • Location must match semantic model location
Display and Card Badges
  • Light status badges appear when Points are properly tagged with [“Control”, “Light”] or [“Switch”, “Light”]
  • Equipment must be tagged with [“Lightbulb”] to appear in lighting controls
  • Can use widgetOrder metadata to control display order
Key Differences from Core Semantic Model
  1. Uses its own metadata schema (uiSemantics)
  2. Has specific requirements for equipment grouping
  3. More flexible in allowing consolidated equipment groups
  4. Specific tag requirements for badge display
Light Item Requirements
Simple Switch Light
// Equipment Group
Group    CeilingLightOffice    "Ceiling Light"    (gOffice)    ["Lightbulb"]
    {uiSemantics="uiSemantics"[preposition=" in the ", equipment="Ceiling Light", location="Office"]}
// Switch Item - Must end with _switch
Switch   CeilingLightOffice_switch    "Ceiling Light"    (CeilingLightOffice)    ["Light", "Switch"]
Color Light
// Equipment Group
Group    ColorLightOffice    "Color Light Office"    (gOffice)    ["Lightbulb"]
    {uiSemantics="uiSemantics"[preposition=" in the ", equipment="Color Light", location="Office"]}
// Required Items - Must use exact suffixes
Dimmer   ColorLightOffice_brightness         "Brightness"          (ColorLightOffice)    ["Point", "Control"]
Dimmer   ColorLightOffice_colorTemperature   "Color Temperature"   (ColorLightOffice)    ["Control", "ColorTemperature"]
Color    ColorLightOffice_color              "Color"              (ColorLightOffice)    ["Control", "Light"]
Dimmable Light
// Equipment Group
Group    DimmableLightOffice    "Dimmable Light Office"    (gOffice)    ["Lightbulb"]
    {uiSemantics="uiSemantics"[preposition=" in the ", equipment="Dimmable Light", location="Office"]}
// Required Item - Must end with _brightness
Dimmer   DimmableLightOffice_brightness    "Brightness"    (DimmableLightOffice)    ["Point", "Control"]
Critical Points
  1. Item Naming Suffixes:
    • Switch lights must end with _switch
    • Dimmable lights must end with _brightness
    • Color lights need _brightness, _colorTemperature, and _color
  2. Required Tags:
    • Equipment groups must have [“Lightbulb”]
    • Switch items need [“Light”, “Switch”]
    • Dimmer/Control items need [“Point”, “Control”] or [“Control”, “Light”]
    • Color temperature needs [“Control”, “ColorTemperature”]
  3. Group Membership:
    • Each control item must be a member of its equipment group
    • Equipment groups must be members of their location group
Best Practices
  1. Use consolidated equipment groups for devices typically controlled together
  2. Maintain consistent prepositions within locations
  3. Keep equipment names user-friendly as they appear in UI
  4. Ensure proper tag hierarchy for badge display
The leading “gLoc” is not needed, it might be your favour :wink:
I have been playing with this, hoping to start using the semanticHomeMenu. I have been somewhat baffled on some of the Light Items that i have created. They do not show up for all semantic classes. A good example in my case is that if i set my lightbulb as being in garden or veranda or patio, porch. I wanted to set my outdoor lights but they simply donot show up but as soon I choose room they do show up. Where is this defined?
You can add Room as a non semantic tag to those not showing up.
Thank you. Iam not sure if iam doing the right thing. example, if I have location Garden with semantic class of garden. No lights shows up. If i remove this semantic class and add non-Semantic tag of Room. The semantic class for this Garden is set to Room.
I guess my question is some semantic classes donot allow light to be displayed. why is it behaving that way. i am probably missed the whole point.
The menu is looking for a Room tag, no matter if it is a semantic tag or a non semantic.
You can leave your garden like it is/was, just add Room under non semantic tags.
Thank you for the clarification.
Hello everyone,
Thank you for your great and inspiring work. I have a question regarding the handling of surveillance cameras.
I have an Item configured as follows:
Switch MeineKamera "Kamera im Garten" <video> (gSurveillance) ["Camera", "Switch"] { channel="..." }
Additionally, it has the metadata field “uiSemantics” with the following content:
value: uiSemantics
  preposition: " im"
  equipment: Camera
Despite this, the camera is not displayed by the widget.
Do you have any troubleshooting tips?
Many thanks and best regards
Please do not post in the Marketplace topics but use the discussion topic.
@rlkoshak could you move this two posts please
Edit: Done myself
@Mahoni You need to have Equipments (groups) for your cameras tagged as „Camera“ and your Switch Item needs to be named with the equipment name, followed by „_PowerSwitch“.
Unfortunately, This is not documented and I will add this within the next days.
I keep seeing this in the logs:
2025-05-27 20:25:27.818 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.851 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.852 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_color
2025-05-27 20:25:27.872 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.873 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_color
2025-05-27 20:25:27.888 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.905 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.906 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_color
2025-05-27 20:25:27.926 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.927 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_color
2025-05-27 20:25:27.947 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.948 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_color
2025-05-27 20:25:27.968 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.969 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_color
2025-05-27 20:25:27.988 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.989 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_color
2025-05-27 20:25:27.993 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_colorTemperature
2025-05-27 20:25:27.994 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ledlampjes_keuken_color
I’ve ignored it for months, but now I’m going through logs looking for a specific error, saw this problem, and was distracted. So I did a search, and found this: Attempting to send a state update of an item which doesn't exist - #8 by mpampinos.
I then went through widget, and I suspect the guilty party is the semanticHomeMenu_Lights widget, on lines 183 through 206:
              default:
                - component: Label
                    style:
                      display: "=props.equipmentType === 'ColorLight' ? '' : 'none !important'"
                      font-size: 13px
                      font-weight: var(--f7-list-item-footer-font-weight)
                      line-height: 0.5
                      margin-left: 1rem
                    text: Ambiance
                    visible: "=props.equipmentType === 'ColorLight' ? 'true' : 'false'"
                - component: oh-slider
                    item: "=props.equipmentType != 'ColorLight' ? '' : props.groupItem +
                      '_colorTemperature'"
                    max: 100
                    min: 0
                    style:
                      --f7-range-bar-size: var(--f7-color-picker-slider-size)
                      margin-left: 10px
                      margin-right: 10px
                      margin-top: 15px
                      width: calc(100% - 1rem)
I thought I’d quicly make the item and be done with it. But I can’t, since my thing shelly:shellyrgbw2-white:xxxxxxx doesn’t have “color” channels.
But I don’t fully understand why the widget would want to send commands to this non-existing item? (Cross-checking with the Shelly binding logs, I did turn the light on (or off) right before these log entries, so the timing makes sense.)
You can, just don‘t link it to a channel.
We cannot avoid those warnings, cause the widget cannot check if items exist or not.
You can ignore those warnings and change the log level to error if you don’t want them to be logged.
Of course
 :slight_smile:
Of what type should the items be? Number, String
Color and Number:Temperature
But this will show the controls which are not usefull for you.
Let me think of a better solution.
Not useful, but also not annoying. :slight_smile: The controls have been there all along, by the way. Ideally, they would be only visible with colored led lights, indeed. But I can live with it. :wink:
Something else: I recently made my first ‘scene’, and was pleasantly surprised that those are also integrated. However, when I press the yellow ‘button’, the scene isn’t run, I’m afraid. There’s also no log entry.
Any idea what’s wrong?
