semanticHomeMenu historical consumptions [4.0.0.0;5.9.9.9]
This rule template is a simplified version of my already published historical energy consumption template.
Simplified means, you only need to configure the equipment group item for your meter, no matter what meter type it is. You just need to follow the naming guidelines already used within the semanticHomeMenu.
There will also be a widget to be used within the semanticHomeMenu project.
Language: Blockly/JS Scripting
Changelog
Version 0.1
  • initial release
Resources
uid: hmerk:historical_consumption
label: semanticHomeMenu Historical Consumption
description: semanticHomeMenu Rule Template for historical consumption calculations
configDescriptions:
  - name: persistenceService
    type: TEXT
    context: text
    label: Persistence Service
    description: Persistence service used to store information
    limitToOptions: true
    options:
      - label: default
        value: default
      - label: RRD4J
        value: rrd4j
      - label: MapDB
        value: mapdb
    required: true
  - name: groupItem
    type: TEXT
    context: item
    label: Equipment Group Item
    description: Equipment Group Item
    required: true
triggers:
  - id: "1"
    configuration:
      cronExpression: 1 0 0 * * ? *
    type: timer.GenericCronTrigger
conditions: []
actions:
  - inputs: {}
    configuration:
      blockSource: <xml xmlns="https://developers.google.com/blockly/xml"><block
        type="oh_event" id="DcoZNq7swfEZoj)0Ua]X" x="-820" y="-416"><field
        name="eventType">postUpdate</field><value name="value"><shadow
        type="text" id="#(yQc8CV:OKPW@[kDmLq"><field
        name="TEXT">value</field></shadow><block type="oh_get_persistvalue"
        id="QcdG@s#+KDDo52O!ai.+"><field
        name="methodName">deltaSince</field><value name="itemName"><shadow
        type="oh_item" id="Py}?{~?.icb-QZU-}e|%"><mutation itemName="MyItem"
        itemLabel="MyItem"></mutation><field
        name="itemName">MyItem</field></shadow><block type="oh_item"
        id="{c|-MK@dbovJXw#OdoU%"><mutation
        itemName="{{groupItem}}_MeterValue" itemLabel="Meter
        Value"></mutation><field
        name="itemName">'{{groupItem}}_MeterValue'</field></block></value><value
        name="persistenceName"><shadow type="oh_persistence_dropdown"
        id="a|^dX_MtavSf1=2cxeGW"><field
        name="persistence">default</field></shadow><block
        type="oh_persistence_dropdown" id="u.6YT}kCv9:!jJLX)Ha|"><field
        name="persistence">rrd4j</field></block></value><value
        name="dayInfoSince"><block type="oh_zdt_plusminus"
        id="[bDW~ua-t]1?8nutF9y!"><field name="plusminus">minus</field><field
        name="period">Days</field><value name="offset"><shadow
        type="math_number" id="{sVjuwBlf6dS!(gW*BYk"><field
        name="NUM">0</field></shadow><block type="math_number"
        id="WSiMw);T_W7KBh@4-u_L"><field
        name="NUM">1</field></block></value></block></value></block></value><value
        name="itemName"><shadow type="oh_item"
        id="NPb)7;I@d$=vPq^*MJ)`"><mutation itemName="MyItem"
        id="a8-G;5w)iG|(X+LUPFbs"><mutation
        itemName="{{groupItem}}_UsageDaily" itemLabel="Usage
        Daily"></mutation><field
        name="itemName">'{{groupItem}}_UsageDaily'</field></block></value><next><block
        type="controls_if" id="0?4$NID6H0C9A#:}wuQ!"><value name="IF0"><block
        type="logic_compare" id="U6pYz7%x*I#a`^Y!pGY~"><field
        name="OP">EQ</field><value name="A"><block type="oh_get_zdt_part"
        id="RR$AD9u6D!yHL3_n!WXk"><field
        name="temporalPart">getDayOfWeek</field><value name="zdt"><block
        type="oh_zdt_now"
        id="nYo=K+nRS]V%g#,Pi;t/"></block></value></block></value><value
        name="B"><block type="math_number" id="9%MBAcAkS:LmTC52RXu*"><field
        name="NUM">1</field></block></value></block></value><statement
        name="DO0"><block type="oh_event" id="{8[5EibFv*n^xlsfU_9r"><field
        id="%EWS?a0ed.^2W%u0r/4T"><field
        type="oh_item" id="4~Z=Bm{5152mLS;7$5k}"><mutation itemName="MyItem"
        id="|D|At2K+fPXe#|m]z}MD"><mutation
        type="oh_persistence_dropdown" id="O_c{pjiLi0O6(c+/5ug5"><field
        id="y[1(nPz]4`Nk7Kq#pVMS"><field name="plusminus">minus</field><field
        name="period">Weeks</field><value name="offset"><shadow
        type="math_number" id="%ENY;4,LF9~rYdncN*J."><field
        id="n};3a{3CvDCE)8$V]V9%"><field
        id="#fQEeLvX$:+Ok0s-_ndA"><mutation itemName="MyItem"
        id="4TyCQX|zx,QZlhsj[R4d"><mutation
        itemName="{{groupItem}}_UsageWeekly" itemLabel="Usage
        Weekly"></mutation><field
        name="itemName">'{{groupItem}}_UsageWeekly'</field></block></value><next><block
        type="controls_if" id="|NWnM*J!|AH9]Zfa[w-m"><value name="IF0"><block
        type="logic_compare" id="[E}0z@95rr_-(^9a##Iq"><field
        id="(hY?hpqJyp,-~lbvVgB]"><field
        name="temporalPart">getDayOfMonth</field><value name="zdt"><block
        type="oh_zdt_now"
        id="(Dm;y)NZo`dU-VwwNI,q"></block></value></block></value><value
        name="B"><block type="math_number" id="i{%ezg~{d;[v`o^#g[L,"><field
        name="DO0"><block type="oh_event" id=",%4=aUR`Dp;lZk[vS=iI"><field
        id="*}wUT?2YIi{%UWLFF)R["><field
        type="oh_item" id="E16,H4)4DqzApG}4|Mrm"><mutation itemName="MyItem"
        id="1u;KZKQ;4ytz0hKJT;/f"><mutation
        type="oh_persistence_dropdown" id="`w~opwkei^7CIB3FrO+."><field
        id="Z?~MSD!-em3!8FSpdz8c"><field name="plusminus">minus</field><field
        name="period">Months</field><value name="offset"><shadow
        type="math_number" id="#+a!N7#(|H6,-X8@ROJU"><field
        id=")^WuCM:FMVt1,K*X5STB"><field
        id="u9c,ktf{y}x6}w%8#jj~"><mutation itemName="MyItem"
        id="Sc9a}rvsYblGZ4/n@Rs]"><mutation
        itemName="{{groupItem}}_UsageMonthly" itemLabel="Usage
        Monthly"></mutation><field
        name="itemName">'{{groupItem}}_UsageMonthly'</field></block></value><next><block
        type="controls_if" id="Z|(jQNM~N;sjEs_9,OD,"><value name="IF0"><block
        type="logic_compare" id="~BC$sP`2wv49=P@wbIQl"><field
        id="%X4Q/;r!xG,lPkC3i,~E"><field
        name="temporalPart">getDayOfYear</field><value name="zdt"><block
        type="oh_zdt_now"
        id="1/mF/jsRwX7L}-V/eu8#"></block></value></block></value><value
        name="B"><block type="math_number" id="C8-sV|{33~aWV%c8.]5|"><field
        name="DO0"><block type="oh_event" id="ThuO;#wF9bwNr`GCc#zC"><field
        id="e!g~$Qww)$==?dC|Ph?."><field
        id="#($cP7M_#{wMbxt.#k[b"><mutation
        type="oh_persistence_dropdown" id="3A$FKU5,%6(lF$U]q[Sr"><field
        id="Sy2=fJPU]:hwbCwD+B|Y"><field name="plusminus">minus</field><field
        name="period">Years</field><value name="offset"><shadow
        id="?n62/(a806h70QpkWW+2"><field
        id="?(##OvabvK76gTfk7(Q2"><mutation
        itemName="{{groupItem}}_UsageYearly" itemLabel="Usage
        Yearly"></mutation><field
        name="itemName">'{{groupItem}}_UsageYearly'</field></block></value></block></statement></block></next></block></next></block></next></block></xml>
      type: application/javascript
      script: >
        items.getItem('{{energyUsageDaily}}').postUpdate((items.getItem('{{groupItem}}'+'_MeterValue').persistence.deltaSince(time.ZonedDateTime.now().minusDays(1),
        '{{persistenceService}}')));
        if (((time.ZonedDateTime.now()).dayOfWeek().value()) == 1) {
          items.getItem('{{energyUsageWeekly}}').postUpdate((items.getItem('{{groupItem}}'+'_MeterValue').persistence.deltaSince(time.ZonedDateTime.now().minusWeeks(1), '{{persistenceService}}')));
        if (((time.ZonedDateTime.now()).dayOfMonth()) == 1) {
          items.getItem('{{energyUsageMonthly}}').postUpdate((items.getItem('{{groupItem}}'+'_MeterValue').persistence.deltaSince(time.ZonedDateTime.now().minusMonths(1), '{{persistenceService}}')));
        if (((time.ZonedDateTime.now()).dayOfYear()) == 1) {
          items.getItem('{{energyUsageYearly}}').postUpdate((items.getItem('{{groupItem}}'+'_MeterValue').persistence.deltaSince(time.ZonedDateTime.now().minusYears(1), '{{persistenceService}}')));
    type: script.ScriptAction
