semanticHomeMenu - HVAC
The HVAC widget card used by main_widget will show all kind of HVAC (air conditioner) equipment in a selected room and show controlls based on equipment group members.
Group members need to follow the naming shown in the example Item definition.
Usage and Configuration
Example for textual item import
Group hvacChildroom "HVAC" <climate> (gChildroom) ["HVAC"] {uiSemantics="uiSemantics"[preposition=" in the", equipment="HVAC", location="Childroom"]}
Switch hvacChildroom_power "Power" <switch> (hvacChildroom) ["Control", "Power"]
String hvacChildroom_mode "Mode" <temperature_cold> (hvacChildroom) ["Control", "Temperature"]
Number:Temperature hvacChildroom_ambientTemp "Ambient Temperature" <temperature> (hvacChildroom) ["Measurement", "Temperature"]
Number:Temperature hvacChildroom_targetTemp "Target Temperature" <temperature> (hvacChildroom) ["Temperature", "Setpoint"]
String hvacChildroom_fanSpeed "Fan Speed" <qualityofservice> (hvacChildroom) ["Wind", "Control"]
String hvacChildroom_vanesUpDown "Vane Position Up/Down" <movecontrol> (hvacChildroom) ["Control", "Opening"]
// Some devices have numeric values for mode, fanspeed and vanes position, use a number item instead
//Number hvacChildroom_mode "Mode" <temperature_cold> (hvacChildroom) ["Control", "Temperature"]
//Number hvacChildroom_fanSpeed "Fan Speed" <qualityofservice> (hvacChildroom) ["Wind", "Control"]
//Number hvacChildroom_vanesUpDown "Vane Position Up/Down" <movecontrol> (hvacChildroom) ["Control", "Opening"]
Control Mode, Fanspeed and Vane Position use Item options.
Community
Please check openHAB community for discussions and proposals. Do not post on the marketplace topics.
Changelog
Version 1.0.1
- ressource link corrected
Version 1.0
- initial release for openHAB 4
Resources
https://github.com/hmerk/semanticHomeMenu/raw/main/climate/semanticHomeMenu_HVAC.yaml
