Hi there,
I’m using OH 2.5.0.1 on a Raspi Pi3. Have it running an stable for about half a year now with several Sensors and switches on Wifi mainly using native Shellies and Tasmota flashed devices as well as a few Zigbee devices. Nearly half of devices is controlled by MQTT - using the standard Mosquitto broker.
My current project is a completely selfmade rollershutter solution on 12V DC. Using Wemos D1 mini with Tasmota in rollershutter-mode. As everything runs solar-powered i’m aiming to save as much energy as i can and put the D1 mini into deep sleep. It wakes up every x(5) minutes and then goes to deep sleep again. In deep sleep it consumes a minimum of energy but is of course not able to reveive the MQTT commands.
The idea was to work with retained MQTT commands, so if the device comes up and the command was sent during deep sleep it will be performed anyway, once the device is up and running. I did manage to get that behaviour using MQTT.fx, where I published the message during deep sleep and did close the program. Later, when the D1 mini came up it did the shutter movement as expected. As I did close MQTT.fx before I’m expecting that the broker retained the message correctly (and not the client=MQTT.fx). But from OH I can’t get it working. Using a separate bridge and tried several syntaxes as shown below (no error messages from OH):
Bridge mqtt:broker:MQTTBroker “MQTTBroker” [ host=“127.0.0.1”, port=1883, secure=false, username=“XXX”, password=“XXX”, clientID=“openHAB2”, qos=“1” , retainMessages=true] {
Thing mqtt:topic:Rollo_SZ "Rollos Schlafzimmer" {
Channels:
Type rollershutter : Shutter_Percent_links [ stateTopic="stat/tasmota_65A31F/SHUTTER1", commandTopic="cmnd/tasmota_65A31F/Shutterposition1",retainMessages=true ]
Type rollershutter : Shutter_Percent_mitte [ stateTopic="stat/tasmota_65A31F/SHUTTER2", commandTopic="cmnd/tasmota_65A31F/Shutterposition2",retained=true]
Type string : Control_links [ commandTopic="cmnd/tasmota_65A31F/Shutterposition1", retainMessages=true]
Type string : Control_mitte [ commandTopic="cmnd/tasmota_65A31F/Shutterposition2", retained=true]
The following items are configured:
Rollershutter Rollo_SZlinks “Rollo Schlafzimmer links”
Rollershutter Rollo_SZlinks_Percent “Rollo Schlafzimmer links” {channel=“mqtt:topic:Rollo_SZ:Shutter_Percent_links”}
String Rollo_SZlinks_Control “Rollo SZ links Control” {channel=“mqtt:topic:Rollo_SZ:Control_links”}
The command is sent by a rule like:
if (receivedCommand == DOWN) rollopercent.sendCommand(0)
I’m aware that I need to reset the retained command afterwards (tried it with MQTT.fx with an empty message which worked).
So summarizing I’m struggling to send a retained MQTT command from OH.
Can someone help me out?
Best regards
Frank
