hi,
i have an arduino running to which i send commands via apache+php.
Now i think about to implement this directly in openhab to get rid of apache+php.
can anyone point me to the right binding/way?
This is the function where the magic of sending happens:
function arduino_send($ip, $port, $command)
$res = fsockopen($ip, $port);
stream_set_timeout($res, 10, 0);
if($res)
fwrite($res, $command);
$ret = fgets($res);
if ($ret == "")
$ret = "ERR";
return $ret;
else
return "N/A#";
This is the code i use in an other script, that i call with sendHttpGetRequest:
$response = arduino_send($arduino_ip, $arduino_port, "S.1.0");
The Arduino sends a longer string back as status.
After update str_dummy_refresher_for_rules with this response, i split and substring this response-code.
after this i set a lot of items via if to corresponding states.
var lkrFull = str_dummy_refresher_for_rules.state.toString() // e.g. R2#0.0.0.0.0.0.0.0.0.0.1.1.1.1.0.0
var lkrFullLR = lkrFull.split("#")
var lkrStateL = lkrFullLR.get(0)
var lkrStateR = lkrFullLR.get(1)
var lkrState_00 = lkrStateR.substring( 0, 1)
var lkrState_01 = lkrStateR.substring( 2, 3)
var lkrState_02 = lkrStateR.substring( 4, 5)
var lkrState_03 = lkrStateR.substring( 6, 7)
var lkrState_04 = lkrStateR.substring( 8, 9)
var lkrState_05 = lkrStateR.substring(10, 11)
var lkrState_06 = lkrStateR.substring(12, 13)
var lkrState_07 = lkrStateR.substring(14, 15)
var lkrState_08 = lkrStateR.substring(16, 17)
var lkrState_09 = lkrStateR.substring(18, 19)
var lkrState_10 = lkrStateR.substring(20, 21)
var lkrState_11 = lkrStateR.substring(22, 23)
var lkrState_12 = lkrStateR.substring(24, 25)
var lkrState_13 = lkrStateR.substring(26, 27)
var lkrState_14 = lkrStateR.substring(28, 29)
var lkrState_15 = lkrStateR.substring(30, 31)
thanks for reading
regards
