drpsoares
(Diego Soares)
August 13, 2018, 12:24pm
1
Hi All!
I installed OpenHAB2 and I’m configuring my sitemap and items to control some sonoff relays and a Kodi multimedia system.
The example shown in https://docs.openhab.org/addons/bindings/kodi/readme.html is to use:
Selection item=myKodi_input mappings=[Up='Up', Down='Down', Left='Left', Right='Right', Select='Select', Back='Back', Home='Home', ContextMenu='ContextMenu', Info='Info']
But using this code I have to click in the selection button and then choose an option(up, down, etc).
Instead of this, I want to put individual buttons for each use like this.
Sitemap:
Switch item=myKodi_up mappings=[Up='Up']
Items:
Switch myKodi_up "UP" {channel="kodi:kodi:myKodi:input"}
I tried this code, but it isn’t working.
Is there a way to do this? Maybe with rules and a SendCommnand function.
Thanks!
cweitkamp
(Christoph Weitkamp)
August 13, 2018, 2:40pm
2
Hi Diego,
Please try to link a String item to the channel. I am pretty sure it will work with a Switch element in the sitemap like you already configured.
drpsoares
(Diego Soares)
August 13, 2018, 11:10pm
3
Hi, Christoph!
It worked. Thanks! Now I have Up, Down, Left, Right, Select and Back buttons working.
But I still have problems with Stop button. Stop only works like a switch. Tried to modify the item to String and map sitemap button to send an “ON” command, like instructions in this page https://www.openhab.org/v2.2/addons/bindings/kodi/#channels .
I also tried to use the channel channel=“kodi:kodi:myKodi:inputtext” and send the STOP command, but didn’t worked too.
Switch item=myKodi_stop
Switch myKodi_stop "STOP" <"stop.png"> {channel="kodi:kodi:myKodi:stop"}
Do you have any idea?
Best regards!
cweitkamp
August 14, 2018, 5:35am
4
Sounds good so far. Instead of creating different items for your Up/Down/Left/Right/… buttons you can reuse a single item linked to the input channel.
Items:
String myKodi_input {channel="kodi:kodi:myKodi:input"}
Switch myKodi_stop {channel="kodi:kodi:myKodi:stop"}
Sitemap:
Switch item=myKodi_input mappings=[Up="Up",Down="Down",Left="Left",Right="Right"]
or
Switch item=myKodi_input mappings=[Up="Up"]
Switch item=myKodi_input mappings=[Down="Down"]
My Stop button looks like this.
Switch item=myKodi_stop mappings=[ON="\u23F9"]
