Hello, is it possible to send a Time/Date String on a Switch action?
something like this:
Switch LED_Status “HCI” {mqtt=">[mosquitto:LED/STATUS:command:*:DATETIME]"}
Everything is possible (they say…)
Maybe you should explain what you want to achieve with a little more detail…
You can use a switch to trigger a rule. In a rule, you can create a string that includes some date/time. In the same rule, you can send the string via an MQTT Action.
i have found a way =)
i want only see when the switch was last used
rule "last_switch_action LED"
Item LED_Switch_State changed
postUpdate(LED_DATE, new DateTimeType() )
items:
String LED_Switch_State "LED [MAP(light.map):%s]" {mqtt="<[mosquitto:LED:state:default]"}
DateTime LED_DATE "Datum: [%1$tA, %1$td.%1$tm.%1$tY %1$tT]"
