I need to send a Json message to MQTT
I do not get the Json transformation to work, and I will be sending static commands so I do not really need the transformation.
My plan was to put the Json command this in a rule:
HP_Publish.sendCommand("{"power":"ON","mode":"FAN","temperature":24,"fan":"4","vane":"1","wideVane":"SWING"}")
There are to many " signes in that command, is there some way to solve that?
HP_Publish item is:
String HP_Publish "Heat Pump Publish" { mqtt=">[broker_no_Retain:home/heatpump/set:command:command:*:default]" }
Is it at all possible to use this code to send the MQTT Json?
