There are a couple of different issues here, I suspect. First, @opus is correct. Because you are still on OH3, unless you have manually updated the helper libraries, you must still use the getItem syntax. Forms like this
items.LocalSun_Azimuth.state
Were introduced into JSscripting for OH4.
Next, in JSscripting, if you get the state of an item it has already been converted to a string. You have to use a different property, rawState, to get the state in it’s original, non-string, type. Calling toString on a string isn’t a problem, it’s just not necessary.
Lastly, however, if you just use Nap_allas.toString, that is referencing thetoString function, not calling it. This means that your Nap_allas variable has now become the function itself, not the output of the function! Not surprisingly, sendCommand doesn’t know what to do when you give it a function for input instead of the string it is expecting. To make sure you get the function’s output, you need () after the function name: Nap_allas.toString().
