Send Picture via Telegram not working
openhabian 2.2.
action-telegram - 1.11.0
docs: https://www.openhab.org/addons/actions/telegram/#examples
i want so send a picture via Telegram taken by habpanelviewer tablet.
I have a Image Item. Picture is taken. I can see it on habpanel.
Test Rule sending only text works fine! So there is no Problem with the bot.
But i cant send Pictures.
rule:
rule "Testbild"
when Item Test changed
sendTelegramPhoto("bot", ifirewhz, "Wohnzimmer")
Log:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Testbild': An error occurred during the script execution: Could not invoke method: org.openhab.action.telegram.internal.Telegram.sendTelegramPhoto(java.lang.String,java.lang.String,java.lang.String) on instance: null
or
rule "Testbild"
sendTelegramPhoto("bot", ifirewhz.state.toFullString, "Wohnzimmer")
Log:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Testbild': unsupported protocol: 'data'
Your second erro indicates that the Telegram action is indeed installed but fails due to the content on the info passed to it.
What is the content of ifirewhz?
Have you tried?
rule "Testbild"
    Item Test changed
    sendTelegramPhoto("bot", ifirewhz.state.toString, "Wohnzimmer")
ifirewhz is the Image item
Error in the log with rule:
rule "Testbild"
    Item Test changed
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Testbild': Invalid uri 'raw type (image/jpeg): 27083 bytes': incorrect path
From Telegram action:
sendTelegramPhoto(String group, String photoURL, String caption): Sends a Picture via Telegram REST API
Try to pass an URL to an image, not an Image item
Seems as if you can only use an Image item with the latest OH 2.3 version.
Compare the docs https://www.openhab.org/addons/actions/telegram/ and https://docs.openhab.org/v2.2/addons/actions/telegram/readme.html
:man_facepalming: thanks all
I see:
sendTelegramPhoto("bot1", "http://www.openhab.org/assets/images/openhab-logo-top.png", "sent from openHAB")
