I have multiple z-wave thermostats in my kitchen that can be controlled from BasicUI in OH2 or from the thermostats themselves. When changing the values directly on the thermostats I want the change to be transferred to all the other thermostats so I created a group “TempSetKitchen” that contains all the thermostats. I want to make a rule that changes all the thermostat setpoints when one thermostat is changed. I tried with this ruke:
rule ChangeAllSetpointsKitchen
Item TempSetKitchen received command
TempSetKitchen.members.forEach(item|item.sendCommand(receivedCommand.state))
This doesn’t work. I guess it is the “receivedCommand.state” that is wrong, because if I just add a number her the rule works and all thermostats are changed to this value if one thermostat is changed.
Can any body help with the right code?
