- Platform information:
- Hardware: CPUArchitecture/RAM/storage
- OS: what OS is used and which version
- Java Runtime Environment: which java platform is used and what version
- openHAB version:
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
I am using the spotify integration and I want to send the name of the artist to MQTT.
Spotify integration puts the name into this item
String spotify_current_artist
I have created a MQTT item
String mqtt_spotify_current_artist “Artist” { mqtt=">[broker:Spotify/artist:command:*:default]"}
In a rule I manage to send to MQTT if use text:
mqtt_spotify_current_artist.sendCommand(“artist_name”)
but I have never been sucessfull to send the variabel spotify_current_artist to MQTT in a rule
mqtt_spotify_current_artist.sendCommand(spotify_current_artist.state as string)
How shall the line in the rule be formulated that send the variable spotify_current_artist to MQTT?
spotify_current_artist.state.toString
Works perfectly! Thanks
