Hey guys,
I’m trying to use the Telegram binding for notifications.
I have created a simple test rule (okay, two rules ):
var rulename = "test.rules"
val telegramAction = getActions("telegram","telegram:telegramBot:b0c9xxxxx6")
rule "Test 1"
Item Test_Switch changed
telegramAction.sendTelegramQuery(123456L, "<b>Achtung!</b>\nTest!", "test123", "Button")
logInfo(rulename, "Nachricht gesendet.")
rule "Test 2"
Item TelegramReplyId received update
logInfo(rulename, "Antwort eingegangen: "+ TelegramReplyId.state.toString)
logInfo(rulename, "Antwort eingegangen: "+ TelegramMessage.state.toString)
telegramAction.sendTelegramAnswer(TelegramReplyId.state.toString, "Ok!")
logInfo(rulename, "Antwort gesendet.")
If I change the state of the Item Test_Switch, the message was sent successfully. If I answer on the message I will always get the following error, but the answer is sent.
2021-03-10 19:49:00.215 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Test_Switch' received command ON
2021-03-10 19:49:00.216 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Test_Switch' changed from OFF to ON
2021-03-10 19:49:00.273 [INFO ] [openhab.core.model.script.test.rules] - Nachricht gesendet.
2021-03-10 19:49:10.284 [INFO ] [openhab.core.model.script.test.rules] - Antwort eingegangen: test123
2021-03-10 19:49:10.284 [INFO ] [openhab.core.model.script.test.rules] - Antwort eingegangen: Button
2021-03-10 19:49:10.543 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'test-2' failed: null in test
Thank you for your help
