Hi. The Loxone meter functional block is read only. It can’t be updated from outside of the Miniserver, it can only be reseted to zero. If you need such behaviour, you can try to create a Value Selector and use it as the meter value.
Hi @ppieczul, Thank you very much for having a look at this issue. I have now created a Value selector as per your suggestion and set up the Number channel for transmitting the value:
Still, the values are not transmitted to Loxone, although I would guess that the value should have been transmitted to the P input of the Loxone Selection Swich?
Would you expect the meter values to be transmitted during this log? If yes, there is a problem that the binding did not receive any commands, so I would look in how the rule works, if items get updated and if items are correctly connected to the channels.
But there is something else unusual with that log, those sleep messages. There should be just one sleep message until something happens, but the sleep gets interrupted for unknown reason and goes to sleep again. It would be good to find a reason for that. Do you have OH2 or OH3?
Yes, I expected the meter values to be transmitted to the Selection Switch… I am using OH3.
I actually already tried different methods:
through setup of two items, one for the Loxone selection switch and one item for the the meter reading. The rule updates the Loxone item on state update of the meter item. The rule in OH seems to run correctly as the value is updated correctly in OH. So it looks more to me that the communication with Loxone miniserver is not triggered?
through setup of “follow” profile for the selection switch item as in screenshots below (not sure though that my setup is 100% correct)
I wouldn’t get involved with follow profile while you are investigating a problem, it’s confusing enough on its own. In particular, you will not get an events.log of any commands that it issues.
Stick to rule and sendCommand() to resolve the real problem, then use follow if you wish to replace the rule after it’s working.
From the logs it looks like the binding did not receive the command or a wrong type of command or to a channel that does allow to receive commands.
So things to check are:
what is the type of the command sent (should be DecimalType)
what is the channel that the command is sent to (should be number channel of the value selector control - not a dimmer channel, value selector has two channels)
has the command been dispatched to the binding at all - unfortunately I don’t have a log at the entry of command but you can enable some logs in the framework - I don’t know which ones though)
Item MainElectricityMeter_DeliveryTariff1 received update
LoxoneMiniserver_3CaveElecMeterDayTotalNumber.sendCommand(MainElectricityMeter_DeliveryTariff1.state)
MainElectricityMeter_DeliveryTariff1 item from dsmr binding has type “Number:Energy”:
On below screenshot, you can see that the value of MainElectricityMeter_DeliveryTariff1 is well passed to LoxoneMiniserver_3CaveElecMeterDayTotalNumber, at least in OH. Value is the same:
I also captured a log that may help for the sleeping issue log.txt (313.2 KB) . It seems that it systematically occurs after this event: [ket.common.events.AbstractEventDriver] - incomingFrame(BINARY[len=48,fin=true,rsv=…,masked=false]).
Well, actually, I thought that, if both items were of the same Number type, it was not needed, but maybe I am wrong… Of course no problem to leave it anyway.
It was min=1 and max=100 000. I now set min = 0 and also changed the size step =0.001. Don’t know if these two made the difference, but at least, the value is updated again in openhab, but still not in Loxone:
See also attached log log.txt (154.1 KB)
Different things:
Maybe off topic, but I am surpized about this dsmr thing constantly updating to “ONLINE”. [openhab.event.ThingStatusInfoEvent ] - Thing ‘dsmr:dsmrBridge:3d769cb56a’ updated: ONLINE
There is this recurrent [nding.loxone.internal.LxServerHandler] - State update UUID=1006ACBD-0330-DE14-FFFFDCFD3F3801B8 has no controls table., each time followed by the sleeping…
referring to someItem.sendCommand(otherItem.state)
openHAB can be a bit picky, a state type object is not a command type object even if it looks alike to us, e.g. ON or 3.14
This always works! someItem.sendCommand(otherItem.state.toString) someItem.postUpdate(otherItem.state) // because its a state not command
Hi @jclugeon , thanks for the proposal. I tried your suggested solution straight away. Conclusion is similar. The value is updated correctly in OH, but it is not updated in Loxone. So origin of the problem is likely the same…
@Joe_Vray the problem with sending updates to Loxone seems to be that the command that the binding receives is a formatted value represented as a string: 1234 kWh. This is ignored by the binding, since it expects a numerical value. I don’t know how to cause the rule to pass an unformatted value as DecimalType. The problem however seems to be in the type of command passed from the rule to the item and then to the channel.
The interrupted sleep messages are caused by state updates for controls which are not supported by the binding. You may look up your http://miniserver/data/LoxAPP3.json file to find out what type of controls have UUIDs:
147409E3-023C-3F60-FFFF3D261055B08D
1006ACBD-0330-DE16-FFFFDCFD3F3801B8
147409E3-023C-3F8B-FFFF49551EAA3D11
Maybe we can add that support if that is something useful.
