Hello is it possible to send NULL to an item in a rule?
I know it is possible with the expire bindung, but i need to set an item to null in a rule.
I know you can postUpdate(NULL) but it doesnโt really make sense to sendCommand(NULL). What is the binding supposed to do with a NULL command?
And it probably will only work if you use the methods, not the Actions. I.e
myItem.postUpdate(NULL)
Thanks,work fine. It was my fault, i did not intend to send NULL to a thing and could/should have used postUpdate in the first place.
