items:
Group:Contact R_FBTRDevices
Contact R_FBTRDevice_AvReceiver (R_FBTRDevices) {fritzboxtr064="maconline:AA-BB-CC-DD-EE-FF"}
Group:Contact FBTRDevices
Contact FBTRDevice_AvReceiver (FBTRDevices)
rule:
rule "R_FBTRDevices to FBTRDevices"
Member of R_FBTRDevices changed
createTimer(now.plusSeconds(30), [ |
val mapItem = triggeringItem.name.toString.substring(2, triggeringItem.name.toString.length)
logInfo("loggerName", mapItem) // FBTRDevice_AvReceiver
logInfo("loggerName", triggeringItem.state.toString) // OPEN
sendCommand(mapItem, triggeringItem.state.toString) // [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert 'OPEN' to a command type which item 'FBTRDevice_AvReceiver' accepts: [RefreshType].
log:
2021-02-14 14:30:38.091 [vent.ItemStateChangedEvent] - R_FBTRDevice_AvReceiver changed from CLOSED to OPEN
2021-02-14 14:31:08.089 [INFO ] [se.smarthome.model.script.loggerName] - FBTRDevice_AvReceiver
2021-02-14 14:31:08.093 [INFO ] [se.smarthome.model.script.loggerName] - OPEN
2021-02-14 14:31:08.098 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert 'OPEN' to a command type which item 'FBTRDevice_AvReceiver' accepts: [RefreshType].
What am I missing? Why is it not working?
I can’t find anything usefull about “RefreshType”. Shouldn’t it be OpenClosedType, etc.?
When I’m not using toString inside sendCommand(…), there’s a lot of exception:
2021-02-14 14:48:11.960 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 6318 2021-02-14T14:48:11.947+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
val mapItem
logInfo(<XStringLiteralImpl>,<XFeatureCallImplCustom>)
logInfo(<XStringLiteralImpl>,<XMemberFeatureCallImplCustom>)
sendCommand(<XFeatureCallImplCustom>,<XMemberFeatureCallImplCustom>)
} ] threw an unhandled Exception:
java.lang.IllegalStateException: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(java.lang.String,java.lang.String) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1192) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1150) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1136) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:954) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:235) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy4085.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
Caused by: java.lang.IllegalArgumentException: java.lang.ClassCastException@16fef1b
at sun.reflect.GeneratedMethodAccessor1040.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_252]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_252]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1175) ~[?:?]
... 20 more
