sendCommand with special character
I recently bought the aqara Aqara roller shade companion E1.
The payload for changing the position of the blinds should be in this format according to https://www.zigbee2mqtt.io/devices/ZNJLBL01LM.html:
{“position” :X}
My thing is configured like this:
Type string : position [stateTopic="zigbee2mqtt/rolgordijn_keuken", commandTopic="zigbee2mqtt/rolgordijn_keuken/set", transformationPattern="JSONPATH:$.position"]
Item like this:
String                RolgordijnKeukenPosition                                       "Positie"        {channel="mqtt:topic:mosquitto:rolgordijn_keuken:position"}
With my knowlegde i was able to come up with this:
   RolgordijnKeukenPosition.sendCommand( " {"position" :3} " )
But i get the following error:
2022-08-07 22:15:38.121 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘rolgordijn.rules’ has errors, therefore ignoring it: [35,46]: missing ‘)’ at ‘position’
[35,62]: mismatched input ‘)’ expecting ‘end’
I tried lots of variations but i can’t get it to work. Can anyone help me with this one? Feel like i could be missing something simple. The problem is in the " character.
Thanks.
Yep. You can’t have double quotations within double quotations, because you end up with two separate pairs.
I think you can either use single quotes or escape the inner quotation marks with \:
" {'position' :3} "
' {"position" :3} '
" {\"position\" :3} "
I might be wrong about these, as I haven’t had this particular scenario.
Seems to do the trick. Thank you :slight_smile:
You should be able use
zigbee2mqtt/<name>/set/position
as commandTopic.
By this you just should be able to send
RolgordijnKeukenPosition.sendCommand(3)
In addition in this case I would change your channel and item from string to numeric
That also works like a charm.
How did you come up with that?
That’s the default zigbee2mqtt behavior and should work for all attributes you can set.
With this you can link directly a dimmer item to your channel and do not need any kind of rule or additional transformation. Hope it will make your life a bit easier :slight_smile:
Sure does :). Thanks
