When sending this URL https://datalake-prod2018.rbfa.be/graphql?operationName=GetTeamCalendar&variables={"teamId":"218610","language":"nl","sortByDate":"asc"}&extensions={"persistedQuery":{"version":1,"sha256Hash":"bf4be0c185dee11a27079e529a04d41dc692389ada678dac1f2280e056de7b7d"}}
with a sendHttpGetRequest i get the error failed: Illegal character in query at index 82:
even after replacing the { with %7B and the } with %7D…
the same error…
// Global variables/constants
val String filename = "Voetbal.rules"
val java.util.concurrent.locks.ReentrantLock apiLock = new java.util.concurrent.locks.ReentrantLock
val String v1 = "{\"teamId\":\"218610\",\"language\":\"nl\",\"sortByDate\":\"asc\"}"
val String v2 = "{\"persistedQuery\":{\"version\":1,\"sha256Hash\":\"bf4be0c185dee11a27079e529a04d41dc692389ada678dac1f2280e056de7b7d\"}}"
// Get VoetbalKalender
rule "Voetbal: getVoetbalKalender"
Item vgetAccessToken changed to ON
try
apiLock.lock()
var String url = "https://datalake-prod2018.rbfa.be/graphql?operationName=GetTeamCalendar&variables=" + v1 + "&extensions=" + v2
//val headers = newHashMap()
var String jsonData = sendHttpGetRequest(url)
if (jsonData.isNullOrEmpty)
logError(filename, "Cannot update the authorization tokens. JSON-data is empty.")
return;
logInfo(filename, "getVoetbalKalender, Ontvangen jsondata: " + jsonData)
finally
apiLock.unlock()
When executing i receive the error:
failed: Illegal character in query at index 82: https://datalake-prod2018.rbfa.be/graphql?operationName=GetTeamCalendar&variables={"teamId":"218610","language":"nl","sortByDate":"asc"}&extensions={"persistedQuery":{"version":1,"sha256Hash":"bf4be0c185dee11a27079e529a04d41dc692389ada678dac1f2280e056de7b7d"}}
