Howdy. I’ve got a ZW39 dimmable smartplug working in my items and on my Page. On the Page, I have a dimmer level control that can be set to values between 0 and 100. As I slide it from up to down, the log prints this:
11:52:45.701 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ZW39DimmableSmartPlug_Dimmer' received command 31
11:52:45.702 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'ZW39DimmableSmartPlug_Dimmer' predicted to become 31
11:52:45.704 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZW39DimmableSmartPlug_Dimmer' changed from 0 to 31
11:52:45.901 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ZW39DimmableSmartPlug_Dimmer' received command 77
11:52:45.903 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'ZW39DimmableSmartPlug_Dimmer' predicted to become 77
11:52:45.907 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZW39DimmableSmartPlug_Dimmer' changed from 31 to 77
11:52:46.109 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ZW39DimmableSmartPlug_Dimmer' received command 100
11:52:46.112 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'ZW39DimmableSmartPlug_Dimmer' predicted to become 100
11:52:46.119 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZW39DimmableSmartPlug_Dimmer' changed from 77 to 100
Now I’m trying to set up some Rules that will let me set the dimmer level. I can send an OFF Command through a Rule no problem:
11:55:36.560 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ZW39DimmableSmartPlug' received command OFF
11:55:36.565 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'MiniPlug2_Switch' received command OFF
11:55:36.567 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ZW39DimmableSmartPlug_Dimmer' received command OFF
11:55:36.568 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'MiniPlug2_Switch' predicted to become OFF
11:55:36.569 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'ZW39DimmableSmartPlug_Dimmer' predicted to become OFF
11:55:36.570 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZW39DimmableSmartPlug_Dimmer' changed from 100 to 0
But I don’t know how to send a value (1-100). Is there a reference for commands that can be sent to a particular device? Or a common list of commands?
Thanks!
