I have enabled debugging and what I see is that the if I set the port to a value, default is 25, this is ignored and 465 is used.
debug:
2017-01-14 08:30:00.905 [ERROR] [rg.openhab.action.mail.internal.Mail] - Could not send e-mail to 'slavisa.lukic@gmail.com'.
org.apache.commons.mail.EmailException: Sending the email to the following server failed : mail.gmx.net:465
at org.apache.commons.mail.Email.sendMimeMessage(Email.java:1421)
at org.apache.commons.mail.Email.send(Email.java:1448)
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:157)
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:89)
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:67)
at sun.reflect.GeneratedMethodAccessor33.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_111]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_111]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:114)[129:org.eclipse.smarthome.model.script:0.9.0.201701091847]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:77)[130:org.eclipse.smarthome.model.script.runtime:0.9.0.201701091847]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:60)[128:org.eclipse.smarthome.model.rule.runtime:0.9.0.201701091847]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)[104:org.eclipse.smarthome.core.scheduler:0.9.0.201701091847]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)[104:org.eclipse.smarthome.core.scheduler:0.9.0.201701091847]
Caused by: javax.mail.MessagingException: Could not connect to SMTP host: mail.gmx.net, port: 465;
Can anyone give me guess what I am doing wrong. I tried different providers.
No, no difference,
the parameter is somehow ignored.
I changed the hostname, to be sure that I am changing the right config file, and this parameter is taken, not the port.
Yes, strange. I am using the Debian package on the unstable channel via apt-get, and the first time you try to
ssh openhab@localhost -p 8101
it will take a very long time generating the cryptographic key. On my Pi2, it takes so long that the ssh client times out, but on the next attempt it goes directly to the Password: prompt (default password habopen).
openhab> log:tail mail
17:16:30.511 [ERROR] [rg.openhab.action.mail.internal.Mail] - Could not send e-mail to 'slavisa.lukic@gmail.com'.
at sun.reflect.GeneratedMethodAccessor30.invoke(Unknown Source)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:114)[130:org.eclipse.smarthome.model.script:0.9.0.201701140927]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189)[146:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:77)[131:org.eclipse.smarthome.model.script.runtime:0.9.0.201701140927]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:60)[129:org.eclipse.smarthome.model.rule.runtime:0.9.0.201701140927]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)[105:org.eclipse.smarthome.core.scheduler:0.9.0.201701140927]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)[105:org.eclipse.smarthome.core.scheduler:0.9.0.201701140927]
Ah! If I set ssl = true, then port 465 indeed is used, despite of the configured port!
16:52:41.274 [ERROR] [rg.openhab.action.mail.internal.Mail] - Could not send e-mail to 'christian@hailer.eu'.
org.apache.commons.mail.EmailException: Sending the email to the following server failed : webmail.hailer.eu:465
Until we find the cause of this bug, try setting “ssl = false” and “tls=true” explicitly in your mail config
Here is a test JAR. I’m out the door right now so can’t offer installation instructions at the moment, but your existing port=587 should take effect for ssl=true connections, with this change. No new configuration parameter is needed – the existing port= should take effect.
