- Platform information:
- Hardware: Fujitsu , Incore I5 16 GB RAM 250 GB SSD
- OS: Windows 11
- Java Runtime Environment: Zulu17
- openHAB version: 4.2
- Issue of the topic: Email with attachment is not send from rule, without attachment email sending works
what I want to do:
sending a email if a shutter item gets closed /open.
logging is configured that a seperate log is written in …/logs/shutter_01.log
got an error ,
I can’t see if the shutter_01.log is not accessible to the rule,
so I do a test with a file on Volume d:
Maybe I did not uderstand where the rule code is executed
volume d: is on the same computer as openHAB is running
- Rules code related to the issue
- rule language is javascript
this works and the mail is send and received
console.log('execute rule Test Mail backup 002')
var Things = Java.type('org.openhab.core.model.script.actions.Things');
var mailAction = Things.getActions('mail', 'mail:smtp:t_Strato_SMTP');
var aMailHeader ="Test mail Backup 002";
var aMailMsg = "some content";
// send mail
var successSendMail = mailAction.sendMail('xxxxxx@xxxx.de', aMailHeader, aMailMsg);
console.log('execute rule Test Mail backup 002 success: ', successSendMail);
Blockquote
2024-09-28 20:07:44.780 [INFO ] [ion.script.ui.r_test_backup_mail_002] - execute rule Test Mail backup 002
2024-09-28 20:07:45.144 [INFO ] [ion.script.ui.r_test_backup_mail_002] - execute rule Test Mail backup 002 success: true
this does not work:
var aFileUrl = 'file://D:test_datei.txt';
var attachmentUrlList = ["file://D:test_datei.txt"];
var successSendMailWithAttachment = mailAction.sendMailWithAttachment('xxxxxx@xxxx.de', aMailHeader,aMailMsg, aFileUrl );
console.log('execute rule Test Mail backup 002 success: ', successSendMailWithAttachment);
Blockquote
2024-09-28 21:26:17.065 [INFO ] [ion.script.ui.r_test_backup_mail_002] - execute rule Test Mail backup 002
2024-09-28 21:26:17.421 [WARN ] [mail.internal.action.SendMailActions] - Could not send mail: Error at index 0 in: “test_datei.txt”
2024-09-28 21:26:17.422 [INFO ] [ion.script.ui.r_test_backup_mail_002] - execute rule Test Mail backup 002 success: false
another try
this does not work
var successSendMailWithAttachment = mailAction.sendMailWithAttachments(''xxxxxx@xxxx.de', aMailHeader,aMailMsg, attachmentUrlList);
Blockquote
2024-09-28 21:22:45.723 [INFO ] [ion.script.ui.r_test_backup_mail_002] - execute rule Test Mail backup 002
2024-09-28 21:22:46.154 [WARN ] [mail.internal.action.SendMailActions] - Could not send mail: Error at index 0 in: “test_datei.txt”
2024-09-28 21:22:46.155 [INFO ] [ion.script.ui.r_test_backup_mail_002] - execute rule Test Mail backup 002 success: false
What I’m doing wrong?
Help appreciated
