I’m currently using the RFXCOM 2.0.0 binding on OH2 and my Nexa switch can send perfectly to OH. One issue I have is that I can only pickup if I toggle the Nexa switch (on-off-on-off etc.), but I’d like to be able to use e.g. “on-on-on” or “off-off”. Is this configurable or ‘intended’?
Also I’ve found that OH seems to forget the latest state (e.g. “switch on” in the morning, then I have to select “on-off”) on order to receive the “off” command. I assume this is a bug?
