Sending off command to group of lights results in some lights staying on, with missing "changed to" log message
This is a common issue in question of knx (but there are other bindings for which this is true, too). By sending a command to a group Item, this is serialized to many Items. Each Item is commanded at once, but sadly, the Binding does not buffer the commands and so the commands are sent too quick (and this results in loosing some commands).
It’s best practice to configure knx items to use a state return group address. To ensure that the Item always show the real state, you have to set the item to autoupdate=“false”.
Channel
Type switch : ch1 "My switch" [ga="1/0/1+<1/0/2"]  // 1/0/1 : set actuator to ON/OFF, 1/0/2 : get state of actuator
Item:
Switch MySwitch "My Switch [%s]" { channel="knx:bridge:mything:ch1", autoupdate="false" }
If there are lost commands, the common way would be to use a proxy item and a rule instead of the group Item directly:
rule "send all off"
    Item MyProxyItem received command OFF
    MyGroupItem.members.filter[ m|m.state != OFF ].forEach[ i|  // each Light which isn't OFF
        i.sendCommand(OFF)                                      // switch a light OFF
        Thread::sleep(100)                                      // wait 0.1 Seconds
This way the commands are sent with a little delay.
