Hi, as mentioned in other topics, I’m working on linking OH2 with Fibaro HC2. My current approach is to make a program which takes commands as inputs, and sets or gets values from the HC2. This program is executed in OH2 using the Exec binding.
I tried to make one Exec Thing, and wanted to let the different items send the corresponding parameters to this. However, it does not work, and I am not sure whether it is even possible, or if I am on the wrong path.
String Livingroom_TvLight "28 [%s] " { channel="exec:command:cmdtest:input" }
Thing exec:command:cmdtest [command="/home/pi/cmdtest %2$s", autorun=true]
With this example, cmdtest is executed with the dimmer value as its only parameter. I would like it to be executed as cmdtest 28 .
Should I create one thing per Item instead?
