I despair of sending an percentage Number to knx. Working with temperatures works - % ist not.
I set up in knx.things:
Type number-control : knxLuftfeuchteBad [ ga="9.007:3/1/4" ]
and a rule wich triggers sending to the knx bus:
rule "Luftfeuchte Bad für KNX setzen"
Item tempsensor1humidity changed
// Senden an KNX
sendCommand(knxLuftfeuchteBad, (tempsensor1humidity.state as Number).floatValue)
I also tried to set a " + " %“” to the float value, to send the %-sign too. (doesnt work)
I also tried to convert it to a string and replace “.” by “,” (also doesnt work).
In knx the groupadress is also configured as DTP 9.007.
everything works on OH - but in KNX the values doesn’t show up.
