I have defined the item, sitemap and rule for this to work.
It switches the light on and off.
It send RGB 0,0,0 via MQTT, but does not do any colour updates.
What am I missing?
.rules
var HSBType Light_House_Master_Bed_North_valueHSB
var int Light_House_Master_Bed_North_valueRed
var int Light_House_Master_Bed_North_valueGreen
var int Light_House_Master_Bed_North_valueBlue
var String Light_House_Master_Bed_North_valueRGB
// --------------- Rules being tested -------------------------------------
// ----- 160822 MaxG: colour light -----
rule "Set Light_House_Master_Bed_North value"
Item Light_House_Master_Bed_North changed
Light_House_Master_Bed_North_valueHSB = Light_House_Master_Bed_North.state as HSBType
Light_House_Master_Bed_North_valueRed = Light_House_Master_Bed_North_valueHSB.red.intValue
Light_House_Master_Bed_North_valueGreen = Light_House_Master_Bed_North_valueHSB.green.intValue
Light_House_Master_Bed_North_valueBlue = Light_House_Master_Bed_North_valueHSB.blue.intValue
logInfo("MasterBedNorth.rule", "valueRed..: " + Light_House_Master_Bed_North_valueRed.toString)
logInfo("MasterBedNorth.rule", "valueGreen: " + Light_House_Master_Bed_North_valueGreen.toString)
logInfo("MasterBedNorth.rule", "valueBlue.: " + Light_House_Master_Bed_North_valueBlue.toString)
logInfo("MasterBedNorth.rule", "valueHSB..: " + Light_House_Master_Bed_North_valueHSB.toString)
postUpdate(Light_House_Master_Bed_North_R, Light_House_Master_Bed_North_valueRed)
postUpdate(Light_House_Master_Bed_North_G, Light_House_Master_Bed_North_valueGreen)
postUpdate(Light_House_Master_Bed_North_B, Light_House_Master_Bed_North_valueBlue)
Light_House_Master_Bed_North_valueRGB = "Values: "
+ Light_House_Master_Bed_North_valueRed.toString + "; "
+ Light_House_Master_Bed_North_valueGreen.toString + "; "
logInfo("MasterBedNorth.rule", Light_House_Master_Bed_North_valueRGB)
.items
Group gLight_House_Master_Bed_North "Nightstand Max" <switch> (gHouse_Master, gHouse_Lights)
Color Light_House_Master_Bed_North "Nightstand Max" <slider> (gLight_House_Master_Bed_North)
Dimmer Light_House_Master_Bed_North_R "Red [%d %%]" <switch> (gLight_House_Master_Bed_North) {mqtt=">[mymosquitto:ArgyleCourt/House/Master/Light_House_Master_Bed_North/Red:state:*:default]"}
Dimmer Light_House_Master_Bed_North_G "Green [%d %%]" <switch> (gLight_House_Master_Bed_North) {mqtt=">[mymosquitto:ArgyleCourt/House/Master/Light_House_Master_Bed_North/Green:state:*:default]"}
Dimmer Light_House_Master_Bed_North_B "Blue [%d %%]" <switch> (gLight_House_Master_Bed_North) {mqtt=">[mymosquitto:ArgyleCourt/House/Master/Light_House_Master_Bed_North/Blue:state:*:default]"}
Sitemap
Colorpicker item=Light_House_Master_Bed_North icon="slider"
event log:
2016-08-23 09:22:47 - Light_House_Master_Bed_North received command ON
2016-08-23 09:22:51 - Light_House_Master_Bed_North received command 226.91943127962085,82.74509803921569,100
2016-08-23 09:23:00 - Light_House_Master_Bed_North received command OFF
2016-08-23 09:23:03 - Light_House_Master_Bed_North_R state updated to 0
2016-08-23 09:23:03 - Light_House_Master_Bed_North_G state updated to 0
2016-08-23 09:23:03 - Light_House_Master_Bed_North_B state updated to 0
openHAB log
2016-08-23 09:23:02.014 [INFO ] [del.script.MasterBedNorth.rule] - valueRed..: 0
2016-08-23 09:23:02.247 [INFO ] [del.script.MasterBedNorth.rule] - valueGreen: 0
2016-08-23 09:23:02.504 [INFO ] [del.script.MasterBedNorth.rule] - valueBlue.: 0
2016-08-23 09:23:02.731 [INFO ] [del.script.MasterBedNorth.rule] - valueHSB..: 226.91943127962085,82.74509803921569,0
2016-08-23 09:23:04.620 [INFO ] [del.script.MasterBedNorth.rule] - Values: 0; 0; 0
